Flywheel fitting
09-04-2013, 10:36 PM
Flywheel fitting
I can't remember Confused
Do the flywheel holes only line up in one position on the crankshaft ?
thanks
09-05-2013, 12:18 AM
Flywheel fitting
There are eight holes in a circle... you can put it on any way you like Smile
Some people say you should match mark the flywheel to the crankshaft.
But IMHO, if the flywheel has been balanced, and the crankshaft has been
balanced, I don't see that there is a need for match marking. I didn't do
it on mine, and have yet to see any problem. Most important thing is to
torque the bolts using the correct tightening pattern.
Cheers... jondee86
09-05-2013, 12:35 AM
Flywheel fitting
Yes it was the balance question really and I wonder if Toyota balanced everything together as a unit or balanced individual items separately ?
09-05-2013, 01:45 AM
Flywheel fitting
Difficult to conceive the factory balancing the parts bolted together, and
then taking them apart to assemble the engine. I see balance divots on
the crankshaft and on the flywheel, so I think you can assume they are
balanced by their respective manufacturers. And I'm sure if they had to
go together one particular way, there would be a locating dowel.
Cheers... jondee86
09-05-2013, 08:20 AM
Flywheel fitting
Good morning my friends,
i have a 4age 16v ae92 and intending to install a 4age 20v flywheel!whats your opinion?
4age 16v to FR 20VT
09-05-2013, 08:48 AM
Flywheel fitting
Get the Blacktop (AE111) flywheel... you'll love it Tongue
Cheers... jondee86
09-05-2013, 09:40 AM
Flywheel fitting
Good point about respective manufacturers and I kind of assumed that Toyota would do everything in house but of course you are right in what you are saying, parts will be outsourced.
It all makes perfect sense and I will go ahead and fit my flywheel without
worry Smile
Thanks Jondee Thumbs up!
09-05-2013, 10:59 AM
Flywheel fitting
jondee86 Wrote:Get the Blacktop (AE111) flywheel... you'll love it Tongue
Cheers... jondee86
oh my God!!! Smile Smile make my day mate!!! it is 6 kg i think ?
4age 16v to FR 20VT
09-05-2013, 11:00 AM
Flywheel fitting
totta Crolla Wrote:Good point about respective manufacturers and I kind of assumed that Toyota would do everything in house but of course you are right in what you are saying, parts will be outsourced.
worry Smile
Good luck mate, i am waiting for news Wink Tongue
4age 16v to FR 20VT
09-05-2013, 11:21 AM
Flywheel fitting
There's balancing and then there is balancing. My experience so far showed that factory parts are quite unbalanced for my taste. I.e. a few grams whereas the parts I had balanced are within tiny fractions of a gram.
  Fitting Air Con (No PS) to LHD AE86 pack 7 7,879 01-07-2024 11:36 AM
Last Post: CCB
  Fitting Fibreglass Kouki Lip? chrisae86 3 4,065 02-25-2022 08:14 PM
Last Post: chrisae86
  light weight Flywheel filh 9 11,095 02-05-2018 05:20 PM
Last Post: filh
  Fitting driftworks CS2 coilovers bozu 2 6,657 05-30-2017 10:50 AM
Last Post: bozu
  crank 6 bolt flywheel DJexor 5 10,856 12-05-2016 08:21 AM
Last Post: d3nso
