Flywheel Weight?
03-08-2006, 08:29 AM
Flywheel Weight?
You've never seen the results of an exploding flywheel have you? I suspect it's not something that is guaranteed to go wrong, but if it does it will tear through the metal of your car like it's paper. Seen some pics of a honda where this happened....lets just say he's lucky it was a FWD car cause it could easily have taken a leg off otherwise.
03-11-2006, 03:36 PM
Flywheel Weight?
Heres a pic of my toda next to oem one. bling~!!! I think its around 3.7kg but haven't weighted it after the machine and balance. Its a forged moly...something which makes it safer than lightening oem.
Going in a few days! You can also consider ARP flywheel bolts for high rev. I just got toyota oem replacements as their meant to be very good with some locktite sealant.
[Image: AEU86 AE86 - Flywheel Weight?]
03-13-2006, 12:05 PM
Flywheel Weight?
Ivan141 Wrote:You've never seen the results of an exploding flywheel have you? I suspect it's not something that is guaranteed to go wrong, but if it does it will tear through the metal of your car like it's paper. Seen some pics of a honda where this happened....lets just say he's lucky it was a FWD car cause it could easily have taken a leg off otherwise.
I saw the honda flywheel explode.
Agree with Ivan, just buy real thing.
  AE86 rear axle weight megabob 11 26,252 03-29-2024 11:18 AM
Last Post: FanIsHere
  light weight Flywheel filh 9 11,839 02-05-2018 05:20 PM
Last Post: filh
  crank 6 bolt flywheel DJexor 5 11,321 12-05-2016 08:21 AM
Last Post: d3nso
  Flywheel fitting totta Crolla 11 17,548 11-24-2013 05:31 PM
Last Post: Apsogos
  Steering column weight savings? 4000GT 4 7,920 09-20-2012 08:40 PM
Last Post: 4000GT
