Broken bolts - Water pump
10-04-2011, 07:57 PM
"worst case you'll need to have it helicoiled" - now this would be the really really last resort, because drilling out the screw should be your last resort.
AE86 Full Hybrid - Burns rubber and gasoline |
10-04-2011, 10:04 PM
As it happens I was talking to a specialist welder chap today and he was showing me some of his work and one piece was a recessed snapped bolt with an 'easy out' broken off inside ('easy out' is the super hard but brittle left hand threaded hateful affair mentioned above) the owner of the piece had given up on it as it was also now impossible to drill out.
The welder guy got some copper tube the same outside diameter as the 13mm bolt and Nickel welded enough material onto the bolt through the inside of the tube to enable a nut to be welded on. It then unscrewed ok. He said the key was to build up the weld gradually and use special nickel wire. An analogue brain in a digital World |
10-05-2011, 08:02 PM
Just gave him today a bit of a drill on the screw's head... and it got out with pretty easily..... hahaha
All new stuff comming to my AE86 now! ![]() Regards |
| 20v BT - which oil pump? | Mylesmck | 4 | 5,958 |
| Fuel pump issue | DJexor | 11 | 11,590 |
| Head bolts: You decide..... | oldeskewltoy | 8 | 14,682 |
11-11-2020 06:33 PM Last Post: oldeskewltoy |
| Water Temperature Instrument not moving - Sender Gauge | Hama86 | 8 | 11,803 |
12-06-2017 06:48 PM Last Post: Bean |
| fuel line hose from the pump | Wikizz | 4 | 8,563 |
10-16-2017 07:11 PM Last Post: jdm86gtz |
