Brake caliper
10-20-2005, 03:46 PM
Brake caliper
which Japanese companies do a brake caliper for the AE86?
[Image: AEU86 AE86 - Brake caliper]
http://WWW.AE86IRL.COM
10-20-2005, 04:02 PM
Brake caliper
No one really.
Pads yes, calipers no.
Best option is to use rxy/willwood setup on teh front and whatever you can make fit on the rear, maybe ep70/71 front calipers.
Be sure and sort a balancer/bias to compensate for larger brakes up front! Otherwise youll meet a ditch!
10-20-2005, 04:14 PM
Brake caliper
Wilwood big brake kit is a bit of overkill for a small little hachi. I would go for
RX7 FX first type turbo front setup :-)
  Rear Caliper Rebuild mad.matt 16 24,025 01-19-2017 02:19 PM
Last Post: Project D
  Toyota rear caliper totta Crolla 8 12,415 02-02-2014 11:19 PM
Last Post: totta Crolla
  brake caliper/line fitting Eifelaner 9 16,395 04-15-2013 11:38 AM
Last Post: Eifelaner
  max brake disc thickness ae86 caliper+heel and toe question ditn 26 37,188 10-02-2012 05:00 PM
Last Post: ditn
  Brake master cylinder for FC3S brake conversion Hachi Go 8 18,376 03-03-2011 12:06 AM
Last Post: filh
