Banpei's two door panda Trueno from Japan
10-15-2025, 08:41 PM (This post was last modified: 10-15-2025 08:41 PM by banpei.)
Post: #71
This happened today:
[Image: AEU86 AE86 - Banpei's two door panda Trueno from Japan]
The Dutch people over here probably recognize the place and people in the photo.
For non-Dutch people, the people in the photo are from the Dutch Autoweek car magazine. They have this Youtube feature of putting cars on a rolling road and comparing how much it differs from the official ratings by the manufacturer. I sent in the Trueno nearly two years ago, never heard anything, but got an invitation a few weeks ago
I explained to them I found it very interesting to learn how much my nearly stock engine makes. In Japan it was rated at 130PS, but the test was unstressed (without waterpump, AC, PS, alternator, etc). European cars with a catalytic converter and MAP were rated at 116hp. So, I was hoping it would be more than that. Also, having the Fujitsubo exhaust would probably help a bit.
The results:
122hp with a nearly linear graph! Hurray!
As I had to drive about 45 minutes to the dyno this morning, I decided to make a stop and swap out the 330mm steering wheel for the original. I really can't see anything on the instrument cluster as the rim of the steering wheel is in my view. I found a cheap 350mm steering wheel that I will pick up this weekend and I'll probably put the Luisi up for sale again.
10-17-2025, 09:23 AM
Post: #72
That's some really good results, and a really fun experience!
10-19-2025, 11:08 PM (This post was last modified: 10-19-2025 11:10 PM by banpei.)
Post: #73
Yes, that was definitely a fun experience!
Today I drove the Trueno to a British car autojumble, and it was great to see the Trueno in good company when I came back:
I noticed Jensen just swapped the wipers to the other side for their LHD cars and reversed the motor. That Interceptor must have terrible visibility for the driver with this layout!
Yesterday I also bought a cheap steering wheel to test the visibility on the gauge cluster:
After the drive to the autojumble, I actually got quite fond of this steering wheel. It's got a lovely feel for both 10-to-2 and 9-to-3. As you can see, it didn't come with a horn button, and the Luisi button didn't fit (inner diameter is slightly smaller). Also, the bolt holes aren't recessed, so I have to find a horn that fits and flat bolts.
The seller sold it as 35cm, but actually it's 34cm. The visibility isn't terrible, but 35cm would be the best for an AE86. I'll keep this steering wheel for now and see if I like it in the long run.
I also worked on the seat belt locks today. A comparison between the brown and blue seat belt locks:
As you can see, the blue ones are deteriorating badly. Also the brown ones have some wear, but they don't crumble to (sharp) pieces yet. No wonder my daughter cut herself on them!
I painted the outer sleeves with blue paint and then moved the inside (belt plus lock) from the old to the new sleeves:
I must say this certainly is a huge improvement in safety! Big Grin
10-20-2025, 08:35 PM
Post: #74
What paint do you use for these restaurations? It looks like a good match! And does it last?
10-20-2025, 09:39 PM (This post was last modified: 10-20-2025 09:41 PM by banpei.)
Post: #75
For the caps on the rear parcel shelf I used regular Sikkens paint mixed up in a can. It's the same paint as I used for some other interior parts. Strangely enough, the new paint was much thicker when applied and I wasn't too satisfied with the result. (it was good enough for the parcel shelf)
So, for these I had a can of Motip base coat mixed up. I used plastic primer to make sure the paint bonds with the plastic. I'm not sure how scratch resistant this paint it, but we'll see.
We weren't able to properly scan the color as the interior parts aren't straight enough. We found RAL5008 was the closest match and I went for that.
11-05-2025, 12:57 AM
Post: #76
Good to know!
  Banpei's new TA60 family cruiser banpei 281 309,510 10-30-2024 11:48 PM
Last Post: DarkSupra
  My panda ae86 build Ellzbmx 10 20,167 06-03-2015 10:56 AM
Last Post: Ellzbmx
  JDMitch's 1983 Sprinter Trueno AE86 Panda JDMitch 24 39,587 09-01-2010 11:37 AM
Last Post: nunoturbo
  Re-painting my car [i need Panda 86 photos (high res plz)] daywalker 7 13,259 06-05-2010 02:55 PM
Last Post: jdm86gtz
  Almost a panda. [edit]No more panda![edit] D.Wars 104 105,586 08-26-2009 10:22 PM
Last Post: The Doctor
