Aram's 3SGE Beams Levin Coupe
03-16-2010, 05:52 PM
Post: #71
jesus aram! im surprised you drove your daily around like that!
Brake with the left hand, steer with the right foot...
03-16-2010, 06:35 PM
Post: #72
Livin' on the edge!!!!! Tongue
03-17-2010, 12:14 AM
Post: #73
Cool
btw... does anybody know what these cars use to get the sparks? they have some kind of metal slider underneath...
03-27-2010, 06:29 PM
Post: #74
So I fixed the shock problem, I swapped it with one from the project car. Smile
And today we finaly turned the car on it's side, now the beams under the trunk can be fixed.
After this it's going on the grill. Thumbs up!
Should have update pics later this week!!
[Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]
03-27-2010, 07:29 PM
Post: #75
I think that fender flare should be turned a little bit rear...
You should measure where is a centerpoint on the flare and a rear arch, then put it on right place.
"Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!"
""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff"
-Henri Toivonen 2.5.1986-
http://www.youtube.com/watch?v=OwgB4Xs4LVQ
04-30-2010, 02:52 PM
Post: #76
Yes, good point, this one is coming off, and I will be there when we fix the new one.
This time we will have the new wheels too!
Just got them on Teusday, tires are here the 6th. Smile
Check the difference in white between the wheel and the car hahaha.
06-12-2010, 08:51 PM
Post: #77
Alright, a small update.
Wheels on the car:
Also received my digidash. Thumbs up!
Then we started on the rear arches.
I was not satisfied with first attempt so I was present this time.
So now they are on to my taste. Smile
The Ford fenders are about 1.5 cm wider then standard I think.
The wheel under the car in the next pic have a 20mm spacer.
They are about 10mm too wide so I need 10mm spacers.
I think it will look great actually. Thumbs up!
First steps:
And welded on:
06-13-2010, 10:12 AM
Post: #78
Well done guys, brilliant work, Keeping the ae86 alive indeed
06-13-2010, 10:56 AM
Post: #79
Thanks m8, it's nice to create something alive again from a wreck indeed. Thumbs up!
06-13-2010, 05:45 PM
Post: #80
nice work you have done so far,that was much rust you have found..
what size/brand of wheels is that Dumb question where did you find those??local or..
Yaris 1.3 xp9
Yaris 1.0 p1
Mercedes citan
weekend driver 1985 AE86
  ae86 racecar with beams engine bakonick 151 218,777 06-02-2026 10:33 PM
Last Post: bakonick
  Krullibulls Ae86 BEAMS is the only way krullibull 86 127,386 05-07-2019 09:35 PM
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 22,553 10-07-2018 09:45 PM
  @dodo@ Levin Coupe, renovation and tuning (56k think twice) @dodo@ 165 215,805 03-28-2018 12:35 PM
  AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides Conrad 462 745,360 06-27-2017 12:21 PM
Last Post: DJexor
