Air conditioning R134A swap
01-22-2026, 01:49 AM
Hey guys, is this the kit for the JDM OEM A/C compressor ? I'm going to switch to R134A (the good way) but I don't know which kit to buy..
Context : I have a kouki 10/1985 Sprinter Trueno with all factory manual air conditioning system, it worked "okay" when I got the car from Japan but on very big heat waves it wasn't as cool as I hoped. So I had the great idea to, well, swap from R12 to R134A without swapping anything. A guy hooked up a machine who tested the system, removed the old oil and freon, filled up with new oil and R134A and, it worked, REALLY, REAAALLY well. Like the coldest A/C I've ever felt in my life. Unfortunately, it only lasted from June 2025 to late October 2025, but it worked everyday with no problem. A/C button is blinking, someone told me it was related to low pressure in the system, so, there's a leak (like who could have guessed lol) because R12 is thicker than R134A, so it won't leak through the rings but R134A does. The results : I have now a complete stock R12 system, filled with R134A and R134A oil, but non working. Was working, compressor not seized. I know I need to change the o-rings on the lines, and in the compressor Not sure about the A/C expansion valve if I really need to change it or not? If I can keep myself from removing the entire dash it'll be nice Someone in the MR2 AW11 Facebook group told me to use a RAV4 compressor instead, easier and OEM and bolts right in, but I'm not sure which one to use lol If anyone have ideas...
01-22-2026, 11:10 PM
(This post was last modified: 01-22-2026 11:11 PM by banpei.)
I had mine converted by a professional aircon shop in 2024 and the aircon has been working without an issue since. They only changed the adapter to fill the system. He did tell me first pressurized the system and didn't find any leaks and he didn't replace any O rings. He told me he used a different oil than what you regularly use for R134a as the system is R12, but I have no idea which oil that is.
I can ask them what they used for it, but I'm not sure if they remember me 18 months later. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
01-22-2026, 11:16 PM
(01-22-2026 11:10 PM)banpei Wrote: They only changed the adapter to fill the system. He did tell me first pressurized the system and didn't find any leaks and he didn't replace any O rings. Well actually that's what they did on mine too, it worked beautifully for a while but now it doesn't work lmao I'm so sad tbh... Perhaps I do have a leak? There was some green liquid near the condenser on the plastic when I got the car from Japan, who knows... Gotta call a A/C shop tomorrow! |
07-22-2026, 04:49 PM
I found on the web some documentation from Toyota about the R12 to R134 conversion. And basically they change the orings, the compressor oil, and that's it.
The expansion valve is not mentioned. Mine blew away after I filled the system with gas... bought another one brand new, but haven't tested it yet. |
08-05-2026, 05:11 PM
I've had R134a in mine from before the car left Japan in 2017. Still blows cold with no additional maintenance.
08-09-2026, 12:45 AM
I have my issue, compressor left the chat basically. lmao
Bought a secondhand one from a kouki JDM Levin. Will get it fitted soon. 2007 - Daihatsu Sirion Sport 1.3 (daily) 2007 - Daihatsu Copen 1.3 (secondary car) 1985 - Toyota Sprinter Trueno AE86 2 door (antique car) -> For car pics, Instagram "@taiko_mobile"
08-14-2026, 10:06 PM
i hope you get that fitted soon because its over 30 degrees. when will it end.
peugeot 206 lover i love the ae86 two |
| Fitting Air Con (No PS) to LHD AE86 | pack | 7 | 8,309 |
01-07-2024 11:36 AM Last Post: CCB |
| Air Cleaner Assembly | Hama86 | 7 | 12,911 |
10-29-2018 03:28 AM Last Post: Hama86 |
| AE86 4age engine not starts crank ok backfires to air intake | Ryo | 18 | 25,896 |
08-16-2018 01:36 AM Last Post: Bean |
| Bluetop AFM with air filter | izanagi | 4 | 9,788 |
04-29-2016 07:29 PM Last Post: oldeskewltoy |
| What price clean air ? | totta Crolla | 19 | 27,855 |
04-06-2015 09:31 PM Last Post: banpei |
![AEU86 AE86 - Air conditioning R134A swap [Image: AEU86 AE86 - Air conditioning R134A swap]](https://image.noelshack.com/minis/2026/04/4/1769039191-brave-2026-01-21-21-22-57.png)
![AEU86 AE86 - Air conditioning R134A swap [Image: AEU86 AE86 - Air conditioning R134A swap]](https://www.aeu86.org/sticker-banner-468.gif)
