Air Intake.
08-14-2009, 02:09 AM
Air Intake.
Well I just got my ae86 and ive been searching around seeing what peoples intakes look like. And I havent really found anything. I would like to replace the rubber pipe with a metal unit along with and a MAS adapter and open filter. Could you guys so me your set ups and such. Thanks
[Image: AEU86 AE86 - Air Intake.]
08-14-2009, 09:22 AM
Air Intake.
Only do that if you are interested in less power and more noise (actually not that bad a trade off imho). Otherwise stick a bigger snorkel into the oem filterbox with a oem paper filter and you're golden.
09-12-2009, 02:45 PM
Air Intake.
or would be the ARC box a better solution?
http://www.upgrademotoring.com/performan...xhaust.htm
Pedro Velado
GT-S Owner
09-12-2009, 04:37 PM
Air Intake.
I presume you re running an airflow meter so an ARC filter box probably isn't available I'd say.
I agree, you are better off staying with the standard unit assuming you have it all.
Open pod filters are a con.
  Air conditioning R134A swap sheppardpat47 6 2,272 08-14-2026 10:06 PM
Last Post: jomme_mega
  Fitting Air Con (No PS) to LHD AE86 pack 7 8,378 01-07-2024 11:36 AM
Last Post: CCB
  Air Cleaner Assembly Hama86 7 12,967 10-29-2018 03:28 AM
Last Post: Hama86
  AE86 4age engine not starts crank ok backfires to air intake Ryo 18 26,019 08-16-2018 01:36 AM
  Bluetop AFM with air filter izanagi 4 9,824 04-29-2016 07:29 PM
