Aftermarket or used oil cooler ?
07-17-2006, 09:24 AM
Dreja, just shortcut the oil cooler lines.
You don't need the oil cooler for easy driving until you fix it.
BR
ZaX
07-17-2006, 10:37 AM
firehawk
That’s the wrong way to install a cooler......
The original sandwich plate is a "pressure valve", it means that only if you have excess pressure the oil goes trough the oil cooler, it is not a full flow sandwich plate. This is not good, because as your oil warms up the oil pressure goes down, and less oil goes trough the cooler....
07-17-2006, 06:03 PM
gon Wrote:firehawk That’s the wrong way to install a cooler......
I know. Smile We were going to change it but then sold the car and built a new AE82. Wink In the picture, the oil cooler is also upside down - with the hoses down, there's a possibility that some air will remain at the top of the cooler and it won't operate at full efficiency. The other way around, the cooler would sort of "bleed itself".
  Mocal oil cooler & sandwitch plate ordered Gtsi-R 48 64,315 11-18-2022 02:19 PM
Last Post: FanIsHere
  Oil cooler totta Crolla 0 2,173 07-25-2021 03:25 PM
Last Post: totta Crolla
  Aftermarket / Additional Foglights decryphe 6 11,528 07-08-2017 08:45 AM
  Oil cooler kit izanagi 7 10,183 09-20-2016 11:13 AM
Last Post: harkes
  Permanent oil cooler vs thermostat Lt86 19 24,305 03-28-2015 06:54 PM
Last Post: Lt86
