AE86 booter
05-04-2022, 02:27 PM
Post: #91
AE86 booter
That's a lot of rust replaced by metal! Thumbs up!
[Image: AEU86 AE86 - AE86 booter]
05-04-2022, 03:11 PM (This post was last modified: 05-04-2022 03:44 PM by Mylesmck.)
Post: #92
AE86 booter
outside and in....
[Image: AEU86 AE86 - AE86 booter][Image: AEU86 AE86 - AE86 booter][Image: AEU86 AE86 - AE86 booter][Image: AEU86 AE86 - AE86 booter]
....and nearly there
And finally (?) a niggling little whole at the bootlid catch area...
And of course, more niggly little bits...
At this stage I thought I was ready to `key`the epoxy primer on the underside and finish with a final coat over the entire underside. However, things took a serious turn for the worst....
I spotted this:
Which when I investigated further with a razorblade turned into this:
So I then tackled it with a needle-gun to reveal more
So while contemplating what to do, I found a local blasting firm and got the axle, front subframe and various suspension rods and links blasted
All elevated and ready for spraying. I used Rustbusters epoxy mastic in black; EM121
Not perfect, but it won't be seen that easily as it all goes underneath the car. I found that even though I had thinned and preheated the paint, it started to go off in the gun after a period of time, so it needed to be further thinned..
I thought I may as well do the steering rack brackets and the radiator brackets while I had paint in the gun...
That's us up to date I think. The gasket kit has arrived for the engine rebuild & I've got new crankshaft courtesy of FLOs.ie, rings, bearings, thrust washers and pump internals for the 20v BT rebuild. I have a couple of 16valve pumps that I may use in order to negate the need for the more expensive BT timing belt & risky hydraulic tensioner.
Also SQ Engineerings water kit is here and a set of cops from a Yaris.
Meantime I'm considering getting the underside blasted, if they can leave the engine bay alone as I've got is all finished and ready for topcoat...
05-05-2022, 12:25 AM
Post: #93
AE86 booter
(05-04-2022 02:27 PM)banpei Wrote:  That's a lot of rust replaced by metal! Thumbs up!
I know! And I’d say the car would have looked fairly solid before it was stripped down
05-07-2022, 01:06 AM
Post: #94
AE86 booter
I can’t believe how well the flywheel came up! Just phosphoric acid and a red scotch pad
A few more pieces glass-blasted…
…and I’ve found some bits that needs de-rusting. Can anyone identify them?
Sent from my iPhone using Tapatalk
05-07-2022, 09:52 AM (This post was last modified: 05-07-2022 09:55 AM by Bean.)
Post: #95
AE86 booter
It's been a while since I've been around a Corolla but I think those parts are some of the braces underneath the dashboard or the area inside the rear.
05-07-2022, 11:43 AM
Post: #96
AE86 booter
Thanks Bean, I did wonder if they were part of the centre console/radio area
05-12-2022, 07:55 AM
Post: #97
AE86 booter
Ah yes, those hold the double DIN radio.
05-23-2022, 07:44 PM
Post: #98
AE86 booter
Got a few bits zinc plated...including the pedal boxes
...My project didn't come with much in the way of bolts or fasteners, but I happened across a guy breaking an ae86 & he was good enough to sell me his bucket of bolts:
He also sold me a strut bar, here it is cleaned-up a bit:
The camber plates benefitted from some new pillowball bearings and plated hardware:
Also Painted the coilover/struts with some Epoxy Mastic EM121
05-23-2022, 08:43 PM
Post: #99
Heart AE86 booter
Keep up the good work Myles!
05-24-2022, 12:09 PM
Post: #100
AE86 booter
Smile Thanks @Ivan
  My 20v booter project diggerdolan 2 6,840 10-01-2012 04:45 PM
Last Post: zenki
