toyota a series engine....can a fwd corolla engine be used
10-29-2013, 07:07 PM
i have a general tech question
can any of the fwd corolla engines or mr2 motors be mounted to a rwd transmission? if possible what years and part combinations work together best? any tips, links, and wisdom is appreciated |
10-29-2013, 07:30 PM
do you mean the 4AGE or other 4 type engines?
If 4AGE redtop then yes but you will need to do some modifications intake needs to changed water and oil routes and flywheel |
10-29-2013, 07:44 PM
actually i was under the impression that all 4 a block or parts were interchangeable depending on era
i dont have acess to a 4age and wanted to know options with other corollas/mr2 parts to build a naturally aspirated setup non turbo is their a parts interchange link any where? |
10-29-2013, 10:16 PM
mr2 mk1's only came with 4AGE engines AFAIK, they should fit if you have the necessary RWD bits.
Only other A series engines will fit the T50 gearbox, and none of them is really worth bothering with. A 4AFE is not too bad, but why spend money on such pursuits.. better to just drop in some non-toyota engine/box combination. FABRICA MI DIEM, PVNC! |
10-30-2013, 11:18 PM
The 7AFE to 7AGE modification could be an option though.
1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
Can Wing Mirror Glass be Replaced? | chrisae86 | 1 | 809 |
03-05-2023 09:34 PM Last Post: Ivan141 |
Can you convert your 86 back too the original state? | gh0st | 7 | 2,200 |
04-25-2022 04:25 PM Last Post: gh0st |
Can you seperate trueno kouki bumper lights into zenki bumper lights? | gh0st | 17 | 6,186 |
Can you identify this wheels? Will they fit AE86? | Ryo | 8 | 9,652 |
09-08-2021 12:48 PM Last Post: Ryo |
can i just slam a oem turbo on it ? | MC_JP | 3 | 5,661 |
12-17-2014 11:04 PM Last Post: oldeskewltoy |
