technical asking about TVIS
02-27-2011, 01:02 AM
Hello,
As I'm fixing a standalone ECU system (E-Race) I need some informations about TVIS . Is it fully open at +/- 4000 rpm or higher (4500 rpm) What's voltage is applied to the blue part on T-Vis ( I think it's named VSV Vacuum Switching Valve) Is it 12v or 5v ? Thanks for helping Filh Save the RWD cars |
02-27-2011, 01:49 AM
4200 rpm and 12V
Good luck.... Cheers... jondee86 |
02-27-2011, 01:50 AM
Hi Filh,
It's 12V, and I very much doubt it does anything as subtle as opening partially. Switching point should be somewhere round 4100-4300, but this is based on the original engine characteristic. If you really need to keep TVIS, I'd try to figure out at what point the restriction from closing TVIS starts to hurt power. FABRICA MI DIEM, PVNC! |
02-27-2011, 02:07 AM
Thanks for helping
Yvan , you're right , it's on /off position , fully open , or close . To get the best TVIS openning revs , we'll see that on Dyno bench . My asking was more about voltage , and I got the response very quickly ( was sure , you and Jondee were around) Regards Phil Filh Save the RWD cars |
Early tvis red top from e9 gti small or bigport? | Ryo | 3 | 6,977 |
Tomei 16V poncams + Tomei technical trax 1.5 way LSD | Lt86 | 22 | 17,588 |
09-16-2016 09:56 PM Last Post: Alex170984 |
20v silvertop exhaust manifold on 16v 2nd version tvis motor | Apsogos | 17 | 20,964 |
my tvis doesnt work... | daywalker | 30 | 44,769 |
02-19-2012 01:25 PM Last Post: ZDoman |
Richieu -Technical help desk | richieu | 25 | 35,838 |
08-31-2011 10:32 PM Last Post: NightAddict |
