stock strut shocks (rally)
11-10-2008, 11:40 PM
Most rallye here are Tarmac , with some gravel part . Lets consider it's tarmac only .
I tried coilover ( stock struts lenght and blue TRD/Tokico ) with Swift springs 8kg/mm( I think it's 400lbs) , but it was too soft . I got my large springs back on stock strut plate . I was planning to buy 12", 500lbs spring (60mm dia) from Rally design, and try them with Bilstein rebuilded shocks phil Filh Save the RWD cars |
11-10-2008, 11:47 PM
filh Wrote:I've search about KYb AGX , and read that rear MR2 shocks can be used ! Yes, the MR2 version is short stroke. It's the front btw. But they also have normal stroke version's for the AE86. The MR2-front/Camaro-rear option is for extreme lowering. Techno Toy Tuning sell's the spacer right here: http://www.technotoytuning.com/productdetail.php?p=110 Rokuichi Power !! _________________________________________ Toyota Starlet KP61 2.0 vtec |
11-11-2008, 12:20 PM
AGX and HTS won't do you much good on a rally car, both are short strokes and will drop the height.
11-11-2008, 12:50 PM
Mux213 Wrote:AGX and HTS won't do you much good on a rally car, both are short strokes and will drop the height. See my abobe post... Shock's don't alter rideheight. That's what springs do. Rokuichi Power !! _________________________________________ Toyota Starlet KP61 2.0 vtec |
11-11-2008, 08:50 PM
filh Wrote:Most rallye here are Tarmac , with some gravel part . Lets consider it's tarmac only .Perhaps I should stiffen mine up a bit then Please let me know what it's like, I have a tarmac rally between Christmas and new year and might give these rates a go. An analogue brain in a digital World |
11-12-2008, 01:13 AM
To SX-Machine : confirming , the height is done with springs , shocks work is to absorb the spring "oscilliation"(don't know if it's the correct word in english to speak about spring movement)
So if I read well , despite Bilstein, there's no alternative on shocks with stock lenght . To Totta Corolla . Will leave you feed back , but my next rally is on december 13/14 , and I don't know if I can get all fixed for that date! Phil Filh Save the RWD cars |
11-12-2008, 01:38 AM
KYB agx has stock lenght... Just look at there website.
Koni has stock length. (I had them) Rokuichi Power !! _________________________________________ Toyota Starlet KP61 2.0 vtec |
03-19-2009, 01:51 AM
What are the lenghts of Bilsteins ?
03-20-2009, 08:57 PM
Uzelac Wrote:What are the lenghts of Bilsteins ?Stock height. (not short stroke) An analogue brain in a digital World |
03-20-2009, 10:00 PM
Have you tried TRD??
Last time I check with the dealer here, they still have standard length front shocks. and its adjustable. |
Digital speedometer on stock dashboard | FanIsHere | 0 | 977 |
82mm Stock compression Pistons | apardal | 4 | 2,269 |
rear bilstein B6 shocks 2 types what to choose? | Ryo | 5 | 2,641 |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 11,973 |
Most stock-resembling exhaust for the AE86? | DaLanZhu | 4 | 4,953 |
03-24-2019 04:10 PM Last Post: oldeskewltoy |
