clutches and spring washers position in 2 Way TRD diff????
08-25-2011, 01:40 AM
Hi mates
I'm going to rebuild my LSD, and i have a doubt:
I saw others LSDs that have only one (per side) "spring washer" or others that have two (one spring washer inside, all clutches and the other one outside) in my 2 Way TRD, when i scrapped it i could see that all clutches were inside and the two spring washers outside...is it the correct position in the 2W TRD?
Anybody has an "instructions plane"?
Thanks!
[Image: AEU86 AE86 - clutches and spring washers...D diff????]
08-25-2011, 03:38 AM
http://www.my-acoustic.com/Car/rear_axle...lyze_3.htm
09-01-2011, 10:50 AM
Thanks Project D
Then were in the correct position
Cheers
  ClutchMaxPRO Clutches - Good or Bad? RolanTHUNDER 0 811 12-01-2022 09:55 AM
Last Post: RolanTHUNDER
  Kaaz 1.5 way Diff - Driveshaft Compatability chrisae86 1 2,079 05-10-2021 01:02 PM
Last Post: Project D
  Help needed: is it 1 way or 1.5way LSD Dino86 2 3,270 05-17-2019 09:08 AM
  Gearbox and Diff options MIGGZFSU 35 24,920 03-26-2017 12:00 AM
Last Post: MIGGZFSU
  Tomei 16V poncams + Tomei technical trax 1.5 way LSD Lt86 22 17,621 09-16-2016 09:56 PM
Last Post: Alex170984
