best oil engine for 4a-geu?
09-24-2011, 08:33 PM
Hi, i have a semi stock 4ageu, which is the best engine oil?
any idea? I wanto to change it, but I don't have any idea about it. syntethic?mineral?semi-syntethic? |
09-25-2011, 12:11 AM
I use Castrol GTX (semi-syntethic) 10W40 for my stock engine.
09-25-2011, 02:03 AM
I use the GTX semi in my starlet turbo and i've seen a lot of black stuff under my valve cover.
I would suggest the GOLD series of Eneos and if you find AMS Dominator, then go for them. Another option is Motul 300V but they need more frequent changes due to their chemical stracture. Japan 4 Ever |
09-25-2011, 08:36 AM
Silkolene Race 15W50, Castrol TWS 10W60, Petronas Synthium 1000 10W50
all full synthetic... but mind you we barely get temps below 30°C here so you should be good with a 10W40 AE86 ex-daily |
09-27-2011, 09:11 AM
Thanks, I'll try with Castrol 10W60.
For LSD and gear box? any idea? |
09-27-2011, 12:27 PM
from cavey:
Tranny oils - typical 75W90 GL4 Fresh refill needs about 1.3L Branded: Redline MT90 (GL4 75W90) Diff oils (LSD) Depends a bit on application, for branded LSD's use brand diff oil. KAAZ LSD: KAAZ LSD GL5 oil TRD LSD: TRD LSD oil (FR) CUSCO: Redline diff oils Fresh refill tends to need 1.3L Branded: Castrol 75W140 GL-5 Valvoline Durablend GL-5 LS Motul 90PA LSD MPM SAE-90W GL-g Castrol Saf-Xo i bought gearbox redline mt90 and Motul 90PA LSD |
09-27-2011, 07:44 PM
gearbox: redline MT90
LSD: Redline 75W140 or Castrol SAF-XJ (not Xo !!! this one doesn't work with LSD !) |
Best quality Diffs | gh0st | 1 | 1,085 |
07-03-2022 07:49 PM Last Post: banpei |
Best Induction Kit / Set up | chrisae86 | 20 | 12,331 |
06-10-2020 10:59 AM Last Post: Lykowsky |
Rim width. Which is best.... | Dino86 | 5 | 6,246 |
4age smallport oil pump in bigport engine? | ditn | 2 | 7,641 |
12-06-2014 08:10 PM Last Post: ditn |
trans oil, lsd oil change | Apolan | 9 | 15,939 |
