What is Error code 51 in the GZE?
02-04-2011, 07:07 AM
Hi guys,
I'm seeing the error code 51 in my GZE. 51 Switch signals: TPS idle switch off; neutral start switch off (automatic transmission in Drive); A/C switch on; A/C switch/circuit; A/C amplifier; TPS/circuit; neutral start switch/circuit; ECU The net says the above mentioned points but can anyone tell me whether I can test these myself in the car? thanks alot, Heshan. Cheated on my いたずらな女の子 and now I can't get enough of her.. |
02-04-2011, 07:47 AM
tps is easy to test. You can find the correct values to adjust tsp.. So that i look first!
02-06-2011, 02:28 PM
Thanks Corolla..
I searched but I couldn't find the default setting.. Do you know? Does anyone have a diagram or a How-To on this? Cheated on my いたずらな女の子 and now I can't get enough of her.. |
02-06-2011, 03:05 PM
http://www.ae92gts.com/ae92gts_tps.html
I think i did adjust mine 4agze whit that and is OK do you got Aircon at car? etc? |
02-06-2011, 08:09 PM
yes got aircon.. why?
Got power steering which is becoming a pain as my mechanic deviced a way to to couple the old unit from my GE.. Cheated on my いたずらな女の子 and now I can't get enough of her.. |
02-06-2011, 08:36 PM
Just think that there is TPS and aircon errors what may be the case..
02-14-2011, 03:40 AM
I still haven't found the problem yet. Lets see..
Just getting the car out from my mechanic. Lets see how the condition is. I changed the Fuel filter, did an injector clean up and also changed the water pump.. Filled up SuperCharger with oil!! Old mechanic had left empty!!!! Used A/C Compressor oil. lets see how its going to handle Cheated on my いたずらな女の子 and now I can't get enough of her.. |
4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 6,069 |
DLI GZE no spark | 4agetercel | 5 | 6,664 |
02-01-2013 07:05 PM Last Post: 4agetercel |
GZE Swop with PAS & AC | Lauren | 12 | 12,685 |
02-16-2012 01:04 PM Last Post: heshan |
Engine sounds slush GZE with VIDEO ! | Okami | 13 | 13,557 |
01-03-2012 12:12 PM Last Post: Okami |
GZE swap in a SR5 | TomTom15 | 3 | 4,028 |
11-04-2011 12:30 PM Last Post: MatthewG |
