Trueno Coupe South Africa
06-07-2018, 07:47 PM (This post was last modified: 06-07-2018 07:52 PM by banpei.)
Post: #151
The F20 box is basically the gearbox fitted to the Honda S2000. The engine of the S2000 is called a F20C, hence the name. The gearbox is the same as the ones used in the RX-8 and the IS200/Altezza: the Aisin AZ6. I'm not sure if they are 100% the same as they might have different brackets and such.
Leen produced a conversion kit for these gearboxes to bolt it on the 4AGE. See also these threads:
http://www.aeu86.org/forum/Thread-Assemb...-LEEN-J160
http://www.aeu86.org/forum/Thread-LEEN-G...-quot-A-qu
However after the initial 5 produced, Joe stopped making them. Also http://www.gearboxconversion.com/ seems to be parked at Sedo. Sad
[Image: AEU86 AE86 - Trueno Coupe South Africa]
06-07-2018, 09:40 PM (This post was last modified: 06-07-2018 10:01 PM by MIGGZFSU.)
Post: #152
Aaaahhh awesome thanks for the info
Sent from my F3111 using Tapatalk
Did somemore work on the Shinigami
Test fitted the throttles to make sure all fits
Fitting the pulleys, done the 20v power steering pump and custom made line, fitted the bosch 440 pump, will be temp till I make the surge tank I want.
Test fitting the denso Toyota yaris coils which I had to sand down
Grinding the pully to fit the 60-2 gear [Image: AEU86 AE86 - Trueno Coupe South Africa][Image: AEU86 AE86 - Trueno Coupe South Africa][Image: AEU86 AE86 - Trueno Coupe South Africa][Image: AEU86 AE86 - Trueno Coupe South Africa][Image: AEU86 AE86 - Trueno Coupe South Africa][Image: AEU86 AE86 - Trueno Coupe South Africa][Image: AEU86 AE86 - Trueno Coupe South Africa][Image: AEU86 AE86 - Trueno Coupe South Africa]
Signature removed due to large photobucket message
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 20,562 10-07-2018 09:45 PM
  Track AE86 Build from south america Nurburgring 3 10,091 10-30-2013 07:31 PM
Last Post: BOOMEX
  My Drift project - 83' Trueno coupe doggy 158 315,009 10-23-2012 10:58 AM
Last Post: Lightning
  AE86 Trueno Coupe (SR5-GTS)//Sweden Allexz 71 94,725 03-16-2009 10:02 PM
