Start wont turn over after installing radio
09-16-2014, 11:31 PM
Hey Guys,
When i first bought the car i installed a kenwood radio. When i played some music the starter won't turn over. buy pushing the car and starting there suddenly fixed it. since then the car always ran if i did not play music (did not have any speakers in the car)
Now today i installed my pioneer radio with 2 speaker, (40 watt in the original panels)
After listening to 2 songs i left the car (radio turned off) after that the starter won't go around again -_-"
I just connected the wires to some man made wires under the dash, but they contained old radio stuff where i just added it to.
Gonna fix it soon but what about my starter ?????
Build your dreams.
Ford Puma 1.7 Zetec-s Daily
Toyota AE86 Levin Coupe "Jinxy"- Dreamcar
Mitsubishi sapporo - bosuzoku project
09-17-2014, 12:24 AM
Bad battery/alternator ?
09-17-2014, 10:28 AM
Sounds indeed like a bad battery (or alternator not charging a lot) or a bad ground connection.
The 4age starter is prone to not start with suboptimal batteries. Use a multimeter to check the voltage on your battery (should be 12.2 volts) and start the engine (jump start) and check the voltage again and it should be above 13 volts for a normal charge (around 2000rpm).
If the alternator is to blame the voltage should be below 13 volts when the engine runs, however if this is normal and the battery also has a good voltage you may should check the main ground connection.
[Image: AEU86 AE86 - Start wont turn over after ...ling radio]
09-18-2014, 05:27 PM
Hello guys,
So this is what i did yesterday
*Rolls out the AE86 from the garage* Okay *instert key en turns - klik* DAMN
First thing then : check the battery = 13.40 Volts
Mmmmh should be enough.
*Grabs hammer* Can't stop, hammer time! 1 gentle tap with the hammer on the starter.
*turns key* - *huf huf huf huf huf huf BROAM BROAM*
Fixed.
Then i installed my subwoofer and amp. started the car few times. no problem.
Banpei what are the best batteries for a AE86 ? will be taking a hammer along now when i'm driving Tongue
Build your dreams.
09-22-2014, 04:36 PM
Bad solenoid.
09-22-2014, 11:06 PM
(09-22-2014 04:36 PM)izanagi Wrote:  Bad solenoid.
... or starter motor needs new brushes.
Cheers... jondee86
09-22-2014, 11:13 PM
Cheers... jondee86
Of course.
  Refreshed 20v blacktop first start.. Mylesmck 6 1,227 10-07-2024 07:55 AM
  PWR light issue and no brake fluid after winter storage magpie 10 3,355 05-25-2023 08:09 AM
  Warm start problem DJexor 5 2,707 03-09-2023 10:15 AM
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 1,737 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 7,390 07-31-2019 11:28 AM
