Squeaking noise from engine
08-24-2011, 07:21 PM
Hey guys, theres a terrible squeaking noise coming from my engine when it´s idling. Almost the same noise like a sliping disk brake.
When reving the engine, the squeaking leaves but comes back in idle. Does anybody have an idea what it could be? AE86 Full Hybrid - Burns rubber and gasoline |
08-24-2011, 07:57 PM
Loose or overtight belt?
AE86 ex-daily |
08-24-2011, 08:21 PM
So i just figured out that it´s also there while driving, but only when releasing the throttle and just letting it roll.
But sometimes it squeaks and sometimes it don´t I´ll check the alternator belt tomorow. Can it also squeak when it´s too tight Should i also check the timing belt - i actually thought that it can´t squeak because it can´t slip... On the other hand i don´t think it´s the alternator belt, this would be louder. Damn... AE86 Full Hybrid - Burns rubber and gasoline |
08-25-2011, 07:00 AM
It's more than likely a belt. If you push on the belt and it gives more than 2cm's it is to loose. It should only give about 1cm. If it is to tight It won't give. I'm assuming that this belt has been on for a while though, so it is more than likely loose. You can also pick up a product at your local parts store. It's a spray that removes the built up grease on the belts, but isn't corrosive enough to eat the belt itself. Here's a link n how to use it.
http://autorepair.about.com/od/quicktips...essing.htm Understeer is when the front end hits the wall. Oversteer is when your back end hits the wall. Horsepower is how fast you hit the wall. Torque is how far you take the wall with you! |
08-25-2011, 04:13 PM
Well, the belt tension is ok as i expected. I overhauled the engine only a few months ago so this was supposed to be ok.
Used such a spray on my old winter beater, i´ll see if it helps here. AE86 Full Hybrid - Burns rubber and gasoline |
08-25-2011, 05:35 PM
Hope it goes well!
08-25-2011, 05:39 PM
in case it doesn't if you can record the sound and post it we might recognize it better.
AE86 ex-daily |
08-25-2011, 09:11 PM
Could be a small air leak.
Unlikely but it would be worth checking the cambelt idler pulley. An analogue brain in a digital World |
TRD Short Shifter Rattle Noise, It's Normal? | Mattolo | 18 | 17,116 |
04-18-2024 01:58 PM Last Post: decryphe |
Clicking noise from glove box | chrisae86 | 4 | 1,391 |
09-08-2022 11:36 PM Last Post: chrisae86 |
Noise Insulation for AE86 | decryphe | 1 | 3,665 |
11-03-2016 11:51 AM Last Post: mad.matt |
Whining noise HELP PLEASE | izanagi | 10 | 10,961 |
03-26-2015 06:48 PM Last Post: Komba |
Whining noise only in 4th & 5th. | izanagi | 7 | 9,525 |
09-25-2014 07:09 PM Last Post: Uzelac |
