Size of the fuel lines
04-05-2005, 01:14 PM
The 20 year old fuel lines are very rusted in the tank area and they did not come loose on the red car. To take the fuel tank off, we broke the line, and it needs replacing.
What size is the stock fuel line and the return line? Do we need bigger lines if we plan to use a slightly tuned blacktop engine in the future or will the stock lines be good enough for the task? This would be a good moment to decide what lines to use, since they need replacing anyway.
04-05-2005, 02:16 PM
Just use whatever you can find cheaply. Getting custum fuel lines made means $$$$$$$$$$$
Unless you have some cheap options for fuel resistant, triple breaded fuel hoses there in Latvia. In which case I will be ordering from you too!
Usually its more efficient to just use whatever is under the car or can be found at the junkyard.
04-05-2005, 04:18 PM
Ordinairy fuel lines are cheap. You just have to bend it with the right tools.
Broken down 1984 Trueno HB
[Image: AEU86 AE86 - Size of the fuel lines]
04-05-2005, 05:40 PM
I will see what I can get. But how much reserve there is in the stock lines? Is there any reason to get larger lines if the target is about 160-180hp?
04-05-2005, 08:40 PM
8mm LPG copper lines braided with PVC are cheap and reliable alternative ;-)
04-05-2005, 10:28 PM
Fii Wrote:I will see what I can get. But how much reserve there is in the stock lines? Is there any reason to get larger lines if the target is about 160-180hp?
do not change the size of your fuel lines (unless you started with SR type AE86), they are perfectly good for 300hp as well!
Hurray! Hurray! Hurray! :wink:
oh, just to add: intake 8mm, return 6mm. :wink:
Punky's Corner
04-07-2005, 01:40 AM
What diameter fuel lines does the SR5 have?
  Shim size for AM cams kazi 4 7,075 12-18-2017 05:34 PM
Wink Hub size kazi 5 11,851 06-09-2017 10:06 PM
Last Post: kazi
  braided brake lines izanagi 12 15,155 11-09-2015 01:24 PM
Last Post: The Doctor
  Camshaft sprocket bolt size? harkes 1 5,918 07-03-2015 12:41 PM
Last Post: Dave W
  US-spec vacuum hard lines LordTD 2 6,484 04-27-2015 07:18 PM
Last Post: Project D
