Server outage on Friday 13th
06-13-2008, 02:17 PM
We had some server problems last night. After 2:00 am CET the server hanged and we could not reach it anymore. It must have been because today is Friday 13th!
Normally we have serial console access and a powerbar to powercycle the machine. Serial console didn't give me access since the machine hanged completely and the powerbar failed in shutting off the power. Today someone from the hosting party manually restarted the server at 13:50 so it's back online and we only had just less than 12 hours of downtime! Thanks to Niels for going through the trouble! 1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
06-13-2008, 02:24 PM
good work
i'd suggest check the log files and see whether the linux kernel was killing random processes, and whether apache was potentially hogging all resources causing extreme loads. I remember having a load of 29+ on one of our servers, luckily sshd wasn't killed (yet), it just took about 15 minutes for the shell prompt to arrive, and then some blindtyping and hoping things would work out with a simple apachectl (apache2ctl?) graceful to hotwire apache again Grin. Oh hey banpei, bit offtopic, but i noticed you were on IRCnet too? |
06-13-2008, 04:23 PM
Same error as before: one of the harddisks failing (disappears) and then the RAID failing due to this. However it is set up as a mirror, so it should just continue like nothing is wrong but in reality it hanged the system.
Howerver there is one difference now: during startup the second harddisk failed again and now it's running raid on only one disk. Better check that out this weekend... 1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
06-13-2008, 04:29 PM
ouch, at least you guys are running a raid
good luck with fixing! i/o troubles suck even more |
13th Annual Retro Toyota Gathering UK | Nismo | 1 | 1,058 |
07-19-2023 09:36 AM Last Post: banpei |
Server crashed last sunday | banpei | 17 | 15,958 |
10-25-2012 11:15 AM Last Post: banpei |
Slight problem with the server | banpei | 4 | 5,576 |
05-31-2009 09:34 AM Last Post: nmwisima |
Server problems | banpei | 4 | 5,477 |
06-10-2007 09:27 PM Last Post: Lipinhu |
Server problems | Mux213 | 10 | 8,757 |
01-04-2007 11:43 PM Last Post: banpei |
