Question about AE86 Wheels
09-09-2014, 05:10 AM
hi, guys thanks for time and help i have my AE86
i read the wheel guide from this site my question is i want to change my wheels and i want a wheels like 15x9 offset 0 this measure tire is not necessary to modify the fender? i want to use 195/55/R15 want some 15x9 wheels which do not have to modify the fenders anyone has any ideas thanks http://www.ae86rd.com |
09-09-2014, 08:43 AM
(This post was last modified: 09-09-2014 08:44 AM by Bean.)
What version fenders do you have, kouki or zenki (i.e. with or without plastic trim)?
AE86 ex-daily |
09-09-2014, 05:45 PM
(This post was last modified: 09-09-2014 05:50 PM by CHACAMAN.)
(09-09-2014 08:43 AM)Bean Bandit Wrote: What version fenders do you have, kouki or zenki (i.e. with or without plastic trim)? Hi, thanks for your time and help this is my ride http://www.ae86rd.com |
09-09-2014, 09:51 PM
(This post was last modified: 09-09-2014 09:55 PM by zenki.)
I have 15x8 et0 with 195/50 tires. These will fit without alot of modifications depending how low you car is. Front fenders have the inner lip rolled/ hammered flat and about -2 ... -2,5° camber. Might give it abit more caster so it doesn't rub the wheelwells. Rear arches lip rolled slightly. Might need an adjustable panhard rod to center the rear axle.
ハチロク |
09-10-2014, 01:51 AM
(09-09-2014 09:51 PM)zenki Wrote: I have 15x8 et0 with 195/50 tires. These will fit without alot of modifications depending how low you car is. Front fenders have the inner lip rolled/ hammered flat and about -2 ... -2,5° camber. Might give it abit more caster so it doesn't rub the wheelwells. Rear arches lip rolled slightly. Might need an adjustable panhard rod to center the rear axle. Thanks for your answer one more question and the offset is? http://www.ae86rd.com |
09-10-2014, 02:17 AM
offset (et) 0
ハチロク |
Small question about wheels | Vortrex | 6 | 7,778 |
07-19-2013 01:43 PM Last Post: DJexor |
