Propshaft
04-13-2005, 05:55 PM
Propshaft
Is the propshaft hardened? Or are basicly all car propshafts of hardened steel?
Broken down 1984 Trueno HB |
04-13-2005, 06:33 PM
Propshaft
who cares!
you will need some 700 horses to break it sr86 completed!!........漂うことのマスター!!!! |
04-13-2005, 08:13 PM
Propshaft
I really need to know.
04-14-2005, 01:24 PM
Propshaft
Aico, my opinion - no. They are only well balanced.
04-14-2005, 01:39 PM
Propshaft
I'll just take your word for it then. I hope you are right, because you can weld non hardened steel. Makes things easier for me.
04-14-2005, 01:45 PM
Propshaft
let me guess you need to adjust it cause of thegearbox of the CA18det engine. Good luck with the electronics
Propshaft
Aico, just keep in mind to use non-sewed tubes.
04-14-2005, 02:19 PM
Propshaft
It's just for shortening the shaft. The shaft needs to be welded to the U-joint.
Changing propshaft bearing. Anything I need to know? | Lauren | 5 | 7,777 |
04-15-2012 02:12 AM Last Post: krullibull |
Propshaft options | Jezza_hr | 7 | 6,819 |
10-15-2010 05:22 PM Last Post: Hachi |
rear diff/propshaft clanking/banging at low speed | Uzelac | 5 | 5,102 |
06-20-2010 02:03 AM Last Post: Uzelac |
Propshaft. | 205t16 | 8 | 7,058 |
08-22-2006 07:17 PM Last Post: 205t16 |
Centre Propshaft Bearing - How much play is too much ? | Ian.G | 4 | 4,391 |
10-17-2005 08:53 PM Last Post: richieu |
