P.A.S.S ----- Gear X Crown and Pinion TRD Ratio 4.89 / 5.375
02-01-2011, 07:27 AM
Can you elaborate the exact issue? We purchsed 2 sets from Zenky-Racing and they needed some machining to be able to set the tolerances right...
AE86 ex-daily |
02-01-2011, 10:27 AM
Ok, two problems: First we tried putting a shim between the pinion and main bearing (like the workshop manual states) first was a 98 thou, then a 90, then eventually no shim at all. Basically we cant get the pinion into the housing enough to pull it away from the crown wheel. the contact on the Toe of the leading edge is extreme.
To get it to work without a shim under the bearing, naturally the splines for the flange move up, so to stop the nut bottoming out, a washer had to be put between the nut and the flange at the end of the pinion. This is when I found it abit suspect. So, the second problem is once we get the backlash to this level (which is pretty good actually) the crown wheel tooth depth is bottoming out on the front edge of the pinion...causing it to occasionally bind up. (flank contact) This is still with the tooth contact -way- on the Toe of the crown wheel. Pulling the Crown wheel away from the pinion with the side carrier bearings frees up this binding. But the tooth contact gets worse and then the backlash also becomes very loose. I would like to just check if you had issues with setting the pinion height with no shim. Brake with the left hand, steer with the right foot... |
02-01-2011, 10:43 AM
This sounds exactly the same as the issues we had, our work around was to machine the parts down (shortening the teeth etc... I'm not so good at explaining but I hope you get the point). Btw woper on here had tge same issues also with the zenky-racing r&p.
I guess they all come fom the same factory (Taiwan). I don't think it's a bad product just overpriced considering the additional work that is needed - here's the link to the zenky ones http://www.aeu86.org/viewtopic/zenky-rac...al/start=0 AE86 ex-daily |
02-01-2011, 10:49 AM
Hmm I was going to go with the zenky product. I saw you had issues But went with the Gear x Product because (i thought) it would be slightly better quality.
I guess ill have to suck it up. Im not so mad as the other guy I bought a cw&p is..I have to give him his money back and clearly have to pay for it to get machined before he even wants to look at it again. great! Brake with the left hand, steer with the right foot... |
02-01-2011, 11:01 AM
Well you could always try to get a partial refund from SYM - as the product is clearly faulty... I knew what I was going for with the zenky product as woper had already went through the same but the final price wasok with me.
Hopefully that Taiwan company is going to correct there specs so we don't have to fo through this again and again. crxman: if you read this might be worth forwarding to your supplier AE86 ex-daily |
02-01-2011, 01:42 PM
yeah it would be good, as Ive been thinking about a refund for quite some time. Yet he ignores my emails. Pretty Professional
02-02-2011, 09:14 PM
mc68 Wrote:yeah it would be good, as Ive been thinking about a refund for quite some time. Yet he ignores my emails. Pretty Professional I think he's on holiday in China AE86 GT - SR20DET BlackTop //// Trackday beater Citroen C4 Coupe VTR - 1.6HDi //// Streetcar |
02-03-2011, 12:26 AM
well that explains it
I remove my comment and await his reply Brake with the left hand, steer with the right foot... |
02-15-2011, 12:40 AM
[Walaki]D`Lair Wrote:mc68 Wrote:yeah it would be good, as Ive been thinking about a refund for quite some time. Yet he ignores my emails. Pretty Professional Any idea when he's back?????? Brake with the left hand, steer with the right foot... |
02-15-2011, 01:29 AM
Actually I think it was sarcastic
Shift Gear Clothing - Toyota, Mazda, Turbo, various | tomstwincam | 16 | 18,431 |
07-09-2012 03:37 AM Last Post: tomstwincam |
AE86 5.375 Final Gears - TRD | club-86 | 20 | 19,209 |
01-25-2011 02:05 PM Last Post: Bean |
Rotary T-Shirt Shift Gear S-4XL | tomstwincam | 3 | 4,593 |
11-22-2010 02:26 PM Last Post: tomstwincam |
AE86 Shirt Shift Gear S-4XL | tomstwincam | 8 | 8,610 |
11-22-2010 02:25 PM Last Post: tomstwincam |
Dual Carb T-Shirt Shift Gear S-4XL | tomstwincam | 6 | 6,694 |
11-22-2010 02:24 PM Last Post: tomstwincam |
