OST-068: Smok'n
05-06-2020, 03:03 AM
OST-068: Smok'n
OST-068 is a smok'n Blacktop, its burning oil..... particularly from #4 exhaust valve (wet exhaust port) Why is it smoking??? 1 too many valve seals........... He is lucky that the extra seal didn't cause any damage other then burning some oil My client was a little embarrassed, but it was decided he wanted more power anyway, AND besides those seats(2nd photo in post - above), and valves (below).... ....have seen better days, so I'm building another 20V engine. more to come...... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
06-01-2020, 10:31 AM
OST-068: Smok'n
So what's the plan for this engine overall?
06-01-2020, 10:36 PM
(This post was last modified: 06-02-2020 12:15 AM by oldeskewltoy.)
OST-068: Smok'n
(06-01-2020 10:31 AM)decryphe Wrote: So what's the plan for this engine overall? The plan... the bottom end of the engine gets a complete rebuild, with new Toyota 81.5mm Blacktop pistons, rings, and new bearings. Additionally the bottom end will get fully balanced. The deck height will be set to provide a squish: minimum of .032" (max of .036"). The head has already (previously) been machined .004", I'll be taking about .004" to drop chamber volume about 1cc from before all machine work. The chambers in this head are the best I've seen in any of the Blacktop heads I've worked - No chamber work will be needed Now as nice as the chambers are... some of the ports are not so nice. poor port alignment (core shift) here and here.... Fixing said poor alignment and showing a comparison of 2 intake ports - before and after work More to come..... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
06-03-2020, 09:19 PM
OST-068: Smok'n
3 down........
more to come..... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
06-04-2020, 09:11 PM
OST-068: Smok'n
It's so clean!
1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
07-13-2020, 09:47 PM
OST-068: Smok'n
so... its been a while since I've updated... build is almost finished, just waiting on the new Cometic .036" 20V gasket.
old, and dirty, and look at the pock marks in the exhaust seats Quote: port work complete - prior to valve job - exhaust seats still pock marked if you look closely 4 angle(exhaust), along with ground valves with back cut intakes a bit closer view Head is ready for re-assembled using Supertech springs and as always... it requires small tools (tweezers required) the bottom end got oversize(81.5mm) pistons, and a complete re-balance along with a new MRP oil pan more to come...... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
(Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 1,860 |
OST-093: My, My, Mystery | oldeskewltoy | 10 | 3,162 |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 2,283 |
(Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 1,540 |
(Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 1,238 |
