My Drift project - 83' Trueno coupe
12-09-2010, 07:36 PM
Post: #141
Tank is done
Made a circle from 4mm aluminium sheet to hold the pump cover and etc, and to be a suppor on the tank: ![]() ![]() Also - from the same 4mm alu - made the top cover for the fuel pump / in-out lines: ![]() ![]() Fuel pump braket on the cover, and out / return lines ![]() ![]() Also - the same 4mm support circle for the fuel level sender: ![]() Everything was pressure tested after all the weld where done - and there was only one small spot wich needed reweld
Ex-owner of JDM 83' Trueno Coupe DCw Classic, classic cars restoration, JDM wheels & parts import, sales. http://www.facebook.com/DogCustomWorks +37067170000 |
12-09-2010, 08:08 PM
Post: #142
is very naish!
I like Philip |
12-09-2010, 09:01 PM
Post: #143
can i order 1 or 2 tanks?
toyota corolla coupe 1985 drift car toyota corolla coupe 1987 road car. |
04-11-2011, 11:44 PM
Post: #144
More work has been going latly on this car
Found some time to do some fabrications - so here are update:Done alot of small things that ussualy take bunch of time... Installed Adjustible Cam gears from HKS, redone Intercooler in and out pipes, radiator expansion tank / filler has been done, radioator it self has been rewelded / inlet outlet has been rewelded. Oil filter relocation kit along with all the lines has been installed, turbo feed / return lines has been done and layed fuel lines over the interior. Also - started manufacturing top mount pedals - not alot of done yet - but some sort of shape is visible (by the way - one thin pedal that is visible here - is trottle pedal - not the brake like some people think Also - did all the steering column from 0... still not finished - but its taking shape already also ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() And FINALLY moved to my new garage with Lifters and lots of space - so everything now is 10x easyer!
04-11-2011, 11:45 PM
Post: #145
Finished with oil cooler. Had to reweld AN10 buns on it, fitted all the lines, and installed everything back finally. one job done
04-11-2011, 11:51 PM
Post: #146
And finally started all the assembly, then parts go into the place not temporary
'Hot' side of the motor has been assembled fully. All the lines now are connected, everything is wraped in Heatwrap where its needed.![]() ![]() On the ' cold' side of the motor also some works has been done. Filler tank has been mounted back into its place, radiator also has been mounted back to its place along with 2 fans under it. ![]() ![]() And started to mock up all the plates around intercooler / radiator, and oil cooler. Tomorow will start building them from Aluminium. ![]() ![]() More news soon
04-12-2011, 02:05 AM
Post: #147
nice ride is that a external wastegate you got their ???
04-12-2011, 08:22 AM
Post: #148
Lol, yes, thats the External WG...
04-12-2011, 09:35 AM
Post: #149
lol got one on mine to will up load a pick l8r its a fair bit different to yours
http://www.youtube.com/watch?v=K_Y5bez9bdk how much bhp you looking at getting out of it [/youtube] what gear box you got in her ??? |
04-12-2011, 11:04 AM
Post: #150
TURBO-AE86 Wrote:lol got one on mine to will up load a pick l8r its a fair bit different to yours looking around 280-300hp mark. Will see what turbo can push out. Gearbox is from SXE10 Altezza 6 speed one. Ex-owner of JDM 83' Trueno Coupe DCw Classic, classic cars restoration, JDM wheels & parts import, sales. http://www.facebook.com/DogCustomWorks +37067170000 |
| Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 20,950 |
| Trueno Coupe South Africa | MIGGZFSU | 151 | 149,496 |
06-07-2018 09:40 PM Last Post: MIGGZFSU |
| Scuderia rollator CE86 trueno project | NoHachi | 136 | 191,473 |
04-15-2013 05:53 PM Last Post: [Walaki]D`Lair |
| Ae86 Levin drift project. | filip.alin | 7 | 12,627 |
| my slow trueno project | cfly86 | 38 | 54,649 |
12-12-2012 04:35 AM Last Post: cfly86 |
![AEU86 AE86 - My Drift project - 83' Trueno coupe [Image: AEU86 AE86 - My Drift project - 83' Trueno coupe]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/08122010089_resize.jpg)
![AEU86 AE86 - My Drift project - 83' Trueno coupe [Image: AEU86 AE86 - My Drift project - 83' Trueno coupe]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/08122010090_resize.jpg)
![AEU86 AE86 - My Drift project - 83' Trueno coupe [Image: AEU86 AE86 - My Drift project - 83' Trueno coupe]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/08122010092_resize.jpg)
![AEU86 AE86 - My Drift project - 83' Trueno coupe [Image: AEU86 AE86 - My Drift project - 83' Trueno coupe]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/08122010094_resize.jpg)
![AEU86 AE86 - My Drift project - 83' Trueno coupe [Image: AEU86 AE86 - My Drift project - 83' Trueno coupe]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/09122010096_resize.jpg)
![AEU86 AE86 - My Drift project - 83' Trueno coupe [Image: AEU86 AE86 - My Drift project - 83' Trueno coupe]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/09122010095_resize.jpg)
![AEU86 AE86 - My Drift project - 83' Trueno coupe [Image: AEU86 AE86 - My Drift project - 83' Trueno coupe]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/09122010097_resize.jpg)
![AEU86 AE86 - My Drift project - 83' Trueno coupe [Image: AEU86 AE86 - My Drift project - 83' Trueno coupe]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/DSC_5169_resize.jpg)
![AEU86 AE86 - My Drift project - 83' Trueno coupe [Image: AEU86 AE86 - My Drift project - 83' Trueno coupe]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/DSC_5171_resize-1.jpg)
![AEU86 AE86 - My Drift project - 83' Trueno coupe [Image: AEU86 AE86 - My Drift project - 83' Trueno coupe]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/DSC_5172_resize-1.jpg)
![AEU86 AE86 - My Drift project - 83' Trueno coupe [Image: AEU86 AE86 - My Drift project - 83' Trueno coupe]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/DSC_5173_resize.jpg)
![AEU86 AE86 - My Drift project - 83' Trueno coupe [Image: AEU86 AE86 - My Drift project - 83' Trueno coupe]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/DSC_5181_resize-1.jpg)
![AEU86 AE86 - My Drift project - 83' Trueno coupe [Image: AEU86 AE86 - My Drift project - 83' Trueno coupe]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/DSC_5176_resize-1.jpg)
![AEU86 AE86 - My Drift project - 83' Trueno coupe [Image: AEU86 AE86 - My Drift project - 83' Trueno coupe]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/DSC_5177_resize-1.jpg)
![AEU86 AE86 - My Drift project - 83' Trueno coupe [Image: AEU86 AE86 - My Drift project - 83' Trueno coupe]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/DSC_5178_resize.jpg)
![AEU86 AE86 - My Drift project - 83' Trueno coupe [Image: AEU86 AE86 - My Drift project - 83' Trueno coupe]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/DSC_5198_resize-2.jpg)
![AEU86 AE86 - My Drift project - 83' Trueno coupe [Image: AEU86 AE86 - My Drift project - 83' Trueno coupe]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/DSC_5438_resize.jpg)
![AEU86 AE86 - My Drift project - 83' Trueno coupe [Image: AEU86 AE86 - My Drift project - 83' Trueno coupe]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/DSC_5437_resize.jpg)
![AEU86 AE86 - My Drift project - 83' Trueno coupe [Image: AEU86 AE86 - My Drift project - 83' Trueno coupe]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/DSC_5436_resize.jpg)
![AEU86 AE86 - My Drift project - 83' Trueno coupe [Image: AEU86 AE86 - My Drift project - 83' Trueno coupe]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/DSC_5439_resize.jpg)
![AEU86 AE86 - My Drift project - 83' Trueno coupe [Image: AEU86 AE86 - My Drift project - 83' Trueno coupe]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/DSC_5442_resize.jpg)
![AEU86 AE86 - My Drift project - 83' Trueno coupe [Image: AEU86 AE86 - My Drift project - 83' Trueno coupe]](http://i30.photobucket.com/albums/c308/doggydpit/ae86/DSC_5443_resize.jpg)
