***Ksport*** What about theese coilovers? Cheap?
01-24-2007, 10:30 AM
Post: #61
Ok, tnx. ABout NRCA's - the price is 120$ on t3. normal RCA's 70$, and im sure you know, camber plates are 170$. So those NRCAS are 120$ against 240$ for CP's and normal RCA's. Thats why i thougt about them. on 4 cm lowering they're suppossed to give some 2.5-2.7 degrees of negative camber. Which is i think just about right. What would you suggest?
01-24-2007, 10:34 AM
Post: #62
These calculations are correct. But that way your camber setting will be fixed vs adjustable one (via CPs).
01-24-2007, 04:09 PM
Post: #63
Sorry Jamie, but the cad model was like 2 years and 3 computer crashes ago.. It was just a simple parametric model I made to help understand the roll geometry of McPherson setups, nothing too accurate just rough measures.
01-24-2007, 04:10 PM
Post: #64
You made it once - you can make it again with less problems
01-20-2010, 08:11 PM
Post: #65
Anyone know where go get cheap ae92 Koni shocks?
here i think pair was near 400eur if the adjust is top of shock, |
Carina drivers! - Coilovers for a TA60/62 | nyberrg | 2 | 5,600 |
06-05-2017 10:03 AM Last Post: nyberrg |
Fitting driftworks CS2 coilovers | bozu | 2 | 4,281 |
05-30-2017 10:50 AM Last Post: bozu |
D2 Coilovers any good? | heshan | 18 | 24,442 |
Has anyone tried BC Racing coilovers? | AlexKTM | 9 | 11,082 |
09-05-2016 12:28 PM Last Post: mad.matt |
Anyone running DIY Coilovers? | Rasteirinho | 8 | 12,845 |
