Ivan's coupe: roof stuccowork
08-13-2006, 12:40 PM
Post: #191
hehe,
well that does teach you guys to better diagnose an engine before swapping awell look at the bright side, now you know how to do this Seriously though, very cool, I don't think there are many guys (relatively speaking that is) on this board who'd do what you just did, swap out a (different) engine with little to no previous experience and get it up and running within a day Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
08-13-2006, 12:44 PM
Post: #192
I didnt bring a camera...it would only have slowed us down. We worked 12 hours with only 2 coffee breaks to get it finished on time.
About wether or not I worry too much... Yes I do. It's a fact But I could never be sure y'know... and I couldnt resist installing a 7-rib engine that ran smooth as butter. FABRICA MI DIEM, PVNC! |
08-13-2006, 01:38 PM
Post: #193
yeah in the long run, this will definately proof to be the better solution I'm sure
08-13-2006, 09:58 PM
Post: #194
Keep up the good work Ivan! Are you planning to do the body work soon ?
08-14-2006, 11:39 AM
Post: #195
Still need to get the rear panels.. then need to find someone that has the time to help me with it.
09-27-2006, 08:23 PM
Post: #196
Guys, need some help....
My car is going for it's APK (MOT) this friday, and I have something that is bugging me. I started to notice a slight rumbling noise from my left rear wheel in corners to the right. I thought a bearing had gone bad so I took the half-axle in question out (this one is so loose i can pull it by hand) for inspection. On closer look the bearing feels good as new, but the whole half-axle can move in and out half a millimeter when mounted. I couldnt get the bearing to move when it was out of the car though. What can be causing this? maybe the retainer moved a bit? Also my right rear brake caliper is bad... it always sticka a little and the piston is really hard to turn back in...anyone have a spare somewhere? This one has been like this since I bought the car so it's not bad enough to fail APK, but still...would like to fix it. FABRICA MI DIEM, PVNC! |
09-27-2006, 08:26 PM
Post: #197
Haha, I'm going for MOT tomorow, also with axle problems, we're in for it now Ivan
09-27-2006, 08:46 PM
Post: #198
damn scary
I am going to the first owner of the car for MOT this year, this will be somewhere in october. 1985 AE86 (ハチロク) Levin - Summer time daily driver |
09-29-2006, 06:50 PM
Post: #199
Little update:
Failed the MOT yet again (4 years in a row now...going strong!). No surprises though.. they failed me for having non-captive springs in front.. For those who dont know those springs make the car higher than stock Maybe they sagged a bit since last year they just passed. The other thing was a torn steering knuckle dustcover.. knew that a week ago but forgot it when I was fixing up the rest. I think I'm going to give the crappy lowering springs a shot again in combination with some yellow or red koni's.. FABRICA MI DIEM, PVNC! |
09-29-2006, 06:52 PM
Post: #200
Ivan,
Weird thing is, when the MOT my car they didn't even check my springs.. Sorry to hear she failed man, must be MOT failure week... Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
Front end roof compatibility between 2dr and 3dr | Dochka | 11 | 12,106 |
01-12-2014 05:50 PM Last Post: fax0815 |
