Ian.G's Track/Drift Levin.
02-04-2007, 07:53 PM
Post: #161
Ian.G Wrote:about 1cm or less - just has heel stops and lifts my feet up away from the heat that the exhaust manifold will generate (the primaries are long and the collector is right where your feet are I here it gets a bit warm. Wimp !!!!!!! Good to hear about the progress Ian, once its in there it'll all come together in no time. http://www.ericosullivan.com |
02-05-2007, 10:13 AM
Post: #162
Ah okay, but then I hope your feet aren't too big like mine.
1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
02-08-2007, 02:12 AM
Post: #163
Ian:
What kind of fabric you used to cover your dashboard? It looks sweet... |
02-08-2007, 10:06 AM
Post: #164
Rasteirinho Wrote:Ian: Its electro static flocking - its not a covering like a material of some sort. I believe the surface is covered with something that is electrostatically charged - then the flocking is sprayed and it is attracted to the charged surface and stays there. typical to see this sort of thing in rally cars to help reduce the glare that you get from the dash on the windscreen when you are blasting through the trees. Regards Ian. |
02-08-2007, 03:44 PM
Post: #165
Hi Ian,
Loving the project can't wait to see it when its done. I need to get the dash and some other interior bits flocked in my car. How hard is it to get out and back in again, do you just remove the skin or the whole dash beam etc? regards Matt J.. N2 4AGTTE Replica on VEMS (almost done) |
02-08-2007, 03:52 PM
Post: #166
Quote:N2 4AGTTE Replica on VEMS (almost done) That means bi-turbo ??? |
02-08-2007, 05:31 PM
Post: #167
Team_Dandism Wrote:Hi Ian, No - its pretty easy. You dont remove the main metal beam that carries the steering column. If you take the fronts off the speaker covers, the plastic beneath the steering wheel, centre consoles and instrument cluster you can get to the main bolts that the dashboard/crashpad (as its called in the workshop manuals) in one piece. You'll have to deal with all the pipework for the heater/blower that lives behind but its not too much work to be honest. Regards Ian. |
02-09-2007, 06:13 PM
Post: #168
Great news I'll have a go this weekend, I've found a place in Ipswitch that does it for about 75-80 quid, so i'll get the dash and some of the other interior plastics done while i'm at it.
Thanks for the info Matt J. 4AGTTE N2 Replica (almost done) |
02-21-2007, 02:29 AM
Post: #169
Hey Ian,
I was wondering if you already got some pictures of your car with the run free bodykit? 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
02-21-2007, 10:07 AM
Post: #170
DJexor Wrote:Hey Ian, Sorry man, not yet. The shell is still at NMS being worked upon. The bodykit will probably be the last thing done to the car. Its a shame because I'd like to see what it looks like too. Regards Ian. |
Track AE86 Build from south america | Nurburgring | 3 | 7,701 |
Ae86 Levin drift project. | filip.alin | 7 | 9,108 |
86er's Track rebuild N2.??? Finally an update page 8 | 86er | 191 | 246,048 |
(AUS) 8age trueno track monster! | green_boy_91 | 48 | 53,780 |
KP61: The track fridge | 127 Boy | 20 | 28,738 |
