How to adjust camber on the front using standard adjustment?
06-17-2011, 12:57 PM
Just swap the left and right spring and you should be ok. With your weight added to the right side of the car it should be more or less even. (this is assuming that left is the drivers side of the car).
Can you also measure the ride height, from the front pinchweld to the ground. Should be that the right spring has sagged a bit more then the left. Another option is that your right LCA a bit tweaked and it is now shorter then the right. A wheel to steer the front of the car A pedal to steer the rear |
06-17-2011, 01:20 PM
Sorry, what is LCA? sometimes do not understand some abbreviations in english
06-17-2011, 01:31 PM
[/url]
06-17-2011, 03:42 PM
All right, thanks, Lower Control Arm, i'll raise the car and look this, i've other set of LCA :wink: and 'll looking for any mistakes
06-17-2011, 04:55 PM
You can solve that with camber plates... But check if you have something wrong before. Anyway, from what I noticed, these cars tend to be a bit lower on the driver side, and that increases the camber (negatively). I solved that (height issue) cutting a bit on the back spring form the opposite side...
Handbrake adjustment discs? | DMC | 8 | 648 |
What suspension set up are people using? | kazi | 8 | 7,439 |
07-06-2017 05:26 AM Last Post: headrush |
What is normal and low caster in Cusco camber plates?? | T_AE86 | 9 | 14,175 |
01-07-2016 02:56 AM Last Post: Deuce Cam |
Camber adjustment vs original struts | Lt86 | 9 | 8,646 |
05-07-2015 09:45 PM Last Post: zenki |
Using a different diff in an AE86 | megabob | 6 | 7,451 |
02-17-2015 03:37 PM Last Post: megabob |
