Corolla GT Coupe - Royalty Black
08-28-2013, 03:34 PM
Post: #111
NoHachi Wrote:How did you tune the ignition map if not on the dyno? On the road.... totta Crolla Wrote:37% loss through drivetrain seems like a lot Yeah, usually people say that the dyno there is not that great..... The loss is huge... and i really don't know where i'm losing power.... Still i was very happy with the results. |
08-28-2013, 03:37 PM
Post: #112
pack Wrote:On the road.... How?? A wheel to steer the front of the car A pedal to steer the rear |
08-28-2013, 03:44 PM
Post: #113
Well i was generating log files in the tunerstudio and was turning on the autotune (to control de VE tables).
Then my job was to analyse the log files, and try to figure out when the car missed his ignition (also you can see when pressing the pedal and identify live where the ignition failed, and change the values). Did this process on a track day i had..... Then i would create a new table, and burn it to the megasquirt and would go for a ride... |
08-28-2013, 05:49 PM
Post: #114
"The loss is huge... and i really don't know where i'm losing power"
If it's not seized rear brakes or wheel bearings look closely at the differential and crown wheel and pinion. An analogue brain in a digital World |
08-28-2013, 06:26 PM
Post: #115
Brand new reconditioned rear brakes...
One bearing warned out, doing his noise... Already got a replacement... The pinion and crown are doing a bit of noise, but they are new! The problem is the differential inself.... Must get a LSD! |
08-28-2013, 06:59 PM
Post: #116
Two things, ignition that doesn't miss is still a long way away from having the iginition dialled in to Mean Best Torque or just before detonation (whichever comes sooner). Lotsa power to be found for you on a dyno still I think. Unless you have some sort of special powers
Was the dyno you ran on a Mahle by any chance? Those usually come up with losses in the 40% region. Crank HP is pretty spot on though. A wheel to steer the front of the car A pedal to steer the rear |
08-28-2013, 09:00 PM
Post: #117
Yeah i know!
Dyno day is comming! I still need to learn how to tune the MS using the dyno...... What values i need to check in order to gain power...... What a dyno on a mahle? The dyno was this one Thanks |
08-28-2013, 11:04 PM
Post: #118
Mahle is a manufacturer of Dyno's that have notoriously high driveline loss estimates.
08-29-2013, 05:23 PM
Post: #119
Now i see what you said before.... Still where can i found the ideal ignition timings across table?
I can do two things. Dyno my car WOT or braked. I find it way dificult is to configure the mid values on the table. The 50% TPS values for example...... The WOT values are way more easier to config. Tell me, how can i proceed in order to tune my MS and my ignition timings the best way? What do i need to look for and where? Tahnks |
08-29-2013, 10:26 PM
Post: #120
Best is to buy a book on tuning. That will give you the best basis.
In general you fix each rpm/load bin and add timing until either torque drops off or you get detonation. You are trying to find mean best torque (MBT). Doing that 144 times or more can be a lot of work, so you can also keep the engine at one rpm through the dyno and sweep through tps, add timing, repeat, remove timing, repeat. Keep track of which cells gain or lose torque. etc.. that's it in a nutshell. You need the torque output of the dyno to do this correctly. A wheel to steer the front of the car A pedal to steer the rear |
Gtsi-R red'n black coupé | Gtsi-R | 147 | 118,062 |
02-03-2022 02:43 PM Last Post: Ivan141 |
my 8a9 corolla GT coupe | cloko | 24 | 40,768 |
01-30-2012 05:17 AM Last Post: Sambo |
My UK TE71 Corolla SR Coupe Finished.... | japclassics | 8 | 16,471 |
01-11-2011 02:12 PM Last Post: Pacsker |
my 1984 red over black corolla gt | davegtcoupe | 3 | 10,152 |
10-12-2010 08:14 PM Last Post: davegtcoupe |
RaceMinded satin black Toyota Corolla AE86 Levin Coupe | RaceMinded | 22 | 29,554 |
