Brake questions
01-20-2016, 09:40 AM
(This post was last modified: 01-20-2016 09:57 AM by Bean.)
Brake questions
Well the NS are definately out then.
I personaly never did more than 3 consecutive laps on the ring (max 15 a day) but the B-Spec took it without effort and lasted for a lot longer too. Mind you the ring is actually not very brake intensive compared to other tracks (i.e. Dijon, Spa). So you might want to have a closer look at the HC+ (no to confuse with the HC-CS) - they are more fade resistant than the B-Spec but will wear the discs and themselfs faster. The HC-CS are slightly easier on the discs than the HC+ but offer less a bit less bite though much more linear (unless your setup is very balanced doubt you'll feel the difference) Did a bit of looking up figures and the Carbotech XP8, Brembo HP2000 and B-Spec seam to be very similar (all go upto a max of around 600°C). The XP8 only starting at almost 100°C would be out of question for me (think about the drive to the track). AE86 ex-daily |
01-20-2016, 12:51 PM
(This post was last modified: 01-20-2016 01:10 PM by Project D.)
Brake questions
(01-19-2016 10:03 PM)d3nso Wrote: How did You calculated the break bias? I'm really interested in this S x L x µ then you simply do the F/R ratio S = surface L = lever µ = brake pad coefficient (01-20-2016 09:40 AM)Bean Bandit Wrote: So you might want to have a closer look at the HC+ (no to confuse with the HC-CS)The HC+ is also my favorite when it comes to brake pads for the track. The HC800 is supposed to be between the HC+ and the HC-CS (if you believe their website ) but made in Thailand and not Japan. I would pass... |
01-20-2016, 01:06 PM
Brake questions
Circuito Estoril, agressive driving. 97º on my Brembro rotors. Both of them.
Sorry but this was measured with a sensor right after the session. |
20v Silvertop - New Haltech ECU & Couple of questions | 20valver | 10 | 3,212 |
Windscreen stoopid(?) questions.... | Mylesmck | 7 | 1,662 |
Brake Bias Questions | mad.matt | 10 | 12,153 |
wider rear axle,track width,suspension questions | ditn | 6 | 9,438 |
Suspension questions | leon205gti | 17 | 15,670 |
