Brake questions
01-20-2016, 09:40 AM (This post was last modified: 01-20-2016 09:57 AM by Bean.)
Brake questions
Well the NS are definately out then.
I personaly never did more than 3 consecutive laps on the ring (max 15 a day) but the B-Spec took it without effort and lasted for a lot longer too. Mind you the ring is actually not very brake intensive compared to other tracks (i.e. Dijon, Spa). So you might want to have a closer look at the HC+ (no to confuse with the HC-CS) - they are more fade resistant than the B-Spec but will wear the discs and themselfs faster. The HC-CS are slightly easier on the discs than the HC+ but offer less a bit less bite though much more linear (unless your setup is very balanced doubt you'll feel the difference)
Did a bit of looking up figures and the Carbotech XP8, Brembo HP2000 and B-Spec seam to be very similar (all go upto a max of around 600°C). The XP8 only starting at almost 100°C would be out of question for me (think about the drive to the track).
01-20-2016, 12:51 PM (This post was last modified: 01-20-2016 01:10 PM by Project D.)
Brake questions
(01-19-2016 10:03 PM)d3nso Wrote:  How did You calculated the break bias? I'm really interested in this Smile
S x L x µ
then you simply do the F/R ratio
S = surface
L = lever
µ = brake pad coefficient
(01-20-2016 09:40 AM)Bean Bandit Wrote:  So you might want to have a closer look at the HC+ (no to confuse with the HC-CS)
The HC+ is also my favorite when it comes to brake pads for the track.
The HC800 is supposed to be between the HC+ and the HC-CS (if you believe their website )
but made in Thailand and not Japan. I would pass...
01-20-2016, 01:06 PM
Brake questions
Circuito Estoril, agressive driving. 97º on my Brembro rotors. Both of them.
Sorry but this was measured with a sensor right after the session.
  Brake Bias Questions mad.matt 10 8,223 01-03-2019 04:54 AM
  wider rear axle,track width,suspension questions ditn 6 6,710 10-18-2016 11:50 AM
Last Post: fantapants
  Suspension questions leon205gti 17 11,729 04-30-2016 09:26 PM
Last Post: krullibull
  Engine rebuild questions AlexKTM 20 18,171 07-04-2015 10:17 AM
Last Post: Ghetto
  Group a homologation questions ditn 22 16,716 06-03-2015 08:33 AM
Last Post: ditn
