BT head with ST block.
01-27-2018, 07:26 PM
I am considering this because I cant find a blacktop block. The car in question is a Corolla AE111GT. So I am using over my standard ecu and everything else.
how compatible is a blacktop head with a silvertop block. I know this much. I will need to use the blacktop pistons to avoid contact with the valves.
1)What about the oil pump? Can i use over my blacktop oil pump on the ST block? If i got the St block with its pump can I just exchange the sprocket?
2) Can I use my bt water pump?
3) what timing belt should I use?
4) If I use my blacktop pistons and connecting rod I will have to use crank?
01-28-2018, 07:47 AM (This post was last modified: 01-28-2018 09:44 AM by Project D.)
1) both oil pump will work. 13521-16060 sprocket for the BT pump; 13521-16010 for the ST (and any other 4AG)
2) Yes you can use your water pump (BT & ST share the same water pump pulley 16371-16030)
3) ST belt with ST oil pump (13568-19035), BT belt with BT oil pump (13568-19185)
4) Every 4AG(Z)E (16 or 20v) from 1987 to 2000 use the same crankshaft (13401-16020)
By the way, if you are swapping all you internal parts, you don't need a 20V block, you could take ANY 4AGE block.
Depending on where you live, it could make your life a lot easier.
01-28-2018, 05:54 PM
(01-28-2018 07:47 AM)Project D Wrote:  1) both oil pump will work. 13521-16060 sprocket for the BT pump; 13521-16010 for the ST (and any other 4AG)
I can also use the silvertop connecting rods with the BT pistons? I believe they are stronger.
01-28-2018, 11:15 PM
Apart from the early 16v, every 4A-GE use a 20/42mm connecting rod. So yes, you can use any of them.
But if you already have a set of BT rods, go with those. (They are strong enough and lighter)
01-29-2018, 12:38 PM
(01-27-2018 07:26 PM)CHOPKIN2 Wrote:  I am considering this because I cant find a blacktop block.
Where are you located? I have a spare block.
02-04-2018, 02:35 AM
I am so far away its not funny. I am in the Caribbean. I got in contact with someone that can help me. thank you.
02-06-2018, 06:27 PM
(02-04-2018 02:35 AM)CHOPKIN2 Wrote:  I am so far away its not funny. I am in the Caribbean. I got in contact with someone that can help me. thank you.
Oh! HAHAHAH!
Yeah....I would NOT like to see the shipment costs for that Tongue
  Question about 4AG 20v Engine Block CHACAMAN 1 2,760 06-10-2022 05:17 PM
  4AGE block differences explained (incl. some eyecandy) Bean 46 101,138 05-05-2019 04:03 AM
Last Post: Rocker100
  How important are dowell pins on a 4age block spill86 5 9,591 01-13-2016 11:19 AM
Last Post: spill86
  7 rib block for a bluetop head? dinkers542 7 12,067 11-04-2014 01:44 PM
Last Post: zenki
  20v block with 16v head and internals possible? ditn 3 8,457 08-12-2014 09:19 PM
Last Post: ditn
