AE86 booter
05-04-2022, 02:27 PM
Post: #91
AE86 booter
That's a lot of rust replaced by metal!
1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
05-04-2022, 03:11 PM
(This post was last modified: 05-04-2022 03:44 PM by Mylesmck.)
Post: #92
AE86 booter
outside and in.... ....and nearly there And finally (?) a niggling little whole at the bootlid catch area... And of course, more niggly little bits... At this stage I thought I was ready to `key`the epoxy primer on the underside and finish with a final coat over the entire underside. However, things took a serious turn for the worst.... I spotted this: Which when I investigated further with a razorblade turned into this: So I then tackled it with a needle-gun to reveal more So while contemplating what to do, I found a local blasting firm and got the axle, front subframe and various suspension rods and links blasted All elevated and ready for spraying. I used Rustbusters epoxy mastic in black; EM121 Not perfect, but it won't be seen that easily as it all goes underneath the car. I found that even though I had thinned and preheated the paint, it started to go off in the gun after a period of time, so it needed to be further thinned.. I thought I may as well do the steering rack brackets and the radiator brackets while I had paint in the gun... That's us up to date I think. The gasket kit has arrived for the engine rebuild & I've got new crankshaft courtesy of FLOs.ie, rings, bearings, thrust washers and pump internals for the 20v BT rebuild. I have a couple of 16valve pumps that I may use in order to negate the need for the more expensive BT timing belt & risky hydraulic tensioner. Also SQ Engineerings water kit is here and a set of cops from a Yaris. Meantime I'm considering getting the underside blasted, if they can leave the engine bay alone as I've got is all finished and ready for topcoat... |
05-05-2022, 12:25 AM
Post: #93
AE86 booter | |||
05-07-2022, 01:06 AM
Post: #94
AE86 booter
I can’t believe how well the flywheel came up! Just phosphoric acid and a red scotch pad A few more pieces glass-blasted… …and I’ve found some bits that needs de-rusting. Can anyone identify them? Sent from my iPhone using Tapatalk |
05-07-2022, 09:52 AM
(This post was last modified: 05-07-2022 09:55 AM by Bean.)
Post: #95
AE86 booter
It's been a while since I've been around a Corolla but I think those parts are some of the braces underneath the dashboard or the area inside the rear.
AE86 ex-daily |
05-07-2022, 11:43 AM
Post: #96
AE86 booter
Thanks Bean, I did wonder if they were part of the centre console/radio area
05-12-2022, 07:55 AM
Post: #97
AE86 booter
Ah yes, those hold the double DIN radio.
05-23-2022, 07:44 PM
Post: #98
AE86 booter
Got a few bits zinc plated...including the pedal boxes
...My project didn't come with much in the way of bolts or fasteners, but I happened across a guy breaking an ae86 & he was good enough to sell me his bucket of bolts: He also sold me a strut bar, here it is cleaned-up a bit: The camber plates benefitted from some new pillowball bearings and plated hardware: Also Painted the coilover/struts with some Epoxy Mastic EM121 |
05-23-2022, 08:43 PM
Post: #99
AE86 booter
Keep up the good work Myles! FABRICA MI DIEM, PVNC! |
05-24-2022, 12:09 PM
Post: #100
AE86 booter
Thanks @Ivan
My 20v booter project | diggerdolan | 2 | 5,161 |
10-01-2012 04:45 PM Last Post: zenki |
