4agze timing
04-07-2017, 12:25 AM
4agze timing
Maybe you are right. I will make a last try with a set of peugeot 306gti cops i have on a box...it has 2 wires and it seems it can work.
Ive just wanna make a bit tidy engine bay plus with ic on top of head, plug wires are a bit of mess. Thanks for all the info Cheers |
04-07-2017, 03:10 AM
4agze timing
Post a reply if you have success with this The 2-wire COP's are just small coils
sitting on top of the plug. I think if you wire them in pairs as you originally suggested, they should work. If the GZE igniter can switch larger GZE coilpacks to ground, it should not have any trouble switching two COP's. The GZE igniter will supply the IGf signal for the ECU. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 11,941 |
Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 4,029 |
[Tutorial Video] Setting 4A-GE Ignition Timing | Homem Bomba | 0 | 4,990 |
04-21-2014 02:41 PM Last Post: Homem Bomba |
Broken 20v upper timing belt cover | chip | 2 | 3,938 |
07-16-2012 07:11 AM Last Post: Jan Pedersen |
4AC timing | StarTrekAdmiral | 4 | 9,005 |
04-13-2012 04:49 PM Last Post: StarTrekAdmiral |
