4agze piston in 4age motor
10-10-2008, 09:47 AM
Ken i puth the 4agze piston in one 4age motor?(to make ihttp://cgi.ebay.com/ebaymotors/4AGZE-Pistons-Low-Compression-L-K-No-Resrv-4AGE-BOOST_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1229Q7c39Q3a1Q7c66Q3a2Q7c65Q3a12Q7c240Q3a1318QQ_trksidZp3286Q2ec0Q2em14QQhashZitem140273954673QQitemZ140273954673t turbo)
10-10-2008, 09:48 AM
4agze piston in 4age motor | |||
10-10-2008, 02:40 PM
only if you have the correct crank and connecting rods. (pistons of the 4agze are 20mm pin and the standard 3 ribbed bluetop has 18mm pin.
10-10-2008, 04:37 PM
Moved to technical. This is hardly a project.
1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
10-14-2008, 05:47 AM
Can be done with no troubles. AS long as you have the 20mm rods. If not then you might need a bushing pressed in.
Piston ID | kazi | 5 | 4,961 |
08-11-2019 03:34 PM Last Post: totta Crolla |
86mm piston wizards... | fantapants | 6 | 5,659 |
05-30-2017 02:36 PM Last Post: jdm86gtz |
Piston Identification | Alex170984 | 3 | 4,972 |
05-17-2016 12:47 PM Last Post: Alex170984 |
Piston availability | totta Crolla | 3 | 5,160 |
09-03-2015 09:32 PM Last Post: oldeskewltoy |
which piston is this? | ditn | 10 | 11,206 |
07-04-2014 03:18 PM Last Post: Bean |
