what wheel size 13", 14", 15" use on hachi ?
07-25-2006, 07:27 AM
14" just fits and looks better in my opinion. 15 inch has the advantage of more grip at a lower price. I was happier with 195 tyres (on 14 and 15") than I am with my current 185/60r14's, but that may well be a setup problem with my car that gets more evident with less grippy tyres. UEO also drifts on 185/60r14 all around, and when you look at what he can do with the car, you see those tyres should be fine with a good setup.
07-25-2006, 11:35 AM
Just buy used tires guys.
07-25-2006, 11:49 AM
nmwisima Wrote:Just buy used tires guys. not available unfortunately, atleast not here as 14" is as rare as the car itself AE86 ex-daily |
07-25-2006, 05:00 PM
oldskull Wrote:Sportmax 002 require rolled fender. What means rolled fender ? any pics ?
85' AE86 GT coupe lifetime project since 2005 |
07-25-2006, 06:50 PM
It meens you have to go to that special machine shop that car roll the inner part of the fender (where it turns in).
Hope you understand (maybe someone can do it better?) danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end http://www.jdmbits.com
07-25-2006, 06:56 PM
you can even do that by yourself like this
![]() But I hope you will do it beter and clean like this 1985 AE86 (ハチロク) Levin - Summer time daily driver |
07-25-2006, 09:09 PM
Well still dont understand what must be done if the outside must be widened or the inner of the fenders need some modify well i think i will better understand if i buy them :-) hope it will go well with 195/50 rubber because on our street is using less then 50 is killing of wheels ...really suck our roads. Too much holes.
If i see it right the 1 pic is with standard height and the red hachi has somethink like coilover setup 85' AE86 GT coupe lifetime project since 2005 |
07-25-2006, 09:51 PM
The first pic also modified fender, but he did correctly (i think).
You can use sport max without modified your fender, but your rubber (tyres) will touch the fender. Yes of course you can use 195/50 rubber. Just buy and try it yourself. I am almost buy them too, but I dont want to modify my fender. Still like them original ![]() Oh yes, you can buy Konig Rewinds copy, the wheels named Fast Forward. They are 15x7j 0 offset. The price if I am not wrong about 480 USD for 4 wheels excluding shipping to Europe. 1985 AE86 (ハチロク) Levin - Summer time daily driver |
07-26-2006, 08:27 AM
But the rewinds dont have so deep and stepped lip thats the problem and i want it because its just simply looking a lot lot better.
About the fenders its a not big deal you can do it yourself with one tool
07-26-2006, 08:59 AM
Konig rewind copies are a bit weird.. since rewinds themselves are already copies. Rolled fenders are fenders where the lip on the inside is bent out, and then smoothed and painted.
| Spare wheel & spare wheel carrier | ondafly | 6 | 1,897 |
01-19-2026 01:00 PM Last Post: ondafly |
| Shim size for AM cams | kazi | 4 | 7,996 |
| Hub size | kazi | 5 | 12,828 |
06-09-2017 10:06 PM Last Post: kazi |
| Camshaft sprocket bolt size? | harkes | 1 | 6,428 |
07-03-2015 12:41 PM Last Post: Dave W |
| Oil plug thread size is M18x1.5 ???? | Dino86 | 5 | 12,487 |
06-07-2012 04:54 PM Last Post: Dino86 |
any pics ?
