what wheel size 13", 14", 15" use on hachi ?
07-25-2006, 07:27 AM
14" just fits and looks better in my opinion. 15 inch has the advantage of more grip at a lower price. I was happier with 195 tyres (on 14 and 15") than I am with my current 185/60r14's, but that may well be a setup problem with my car that gets more evident with less grippy tyres. UEO also drifts on 185/60r14 all around, and when you look at what he can do with the car, you see those tyres should be fine with a good setup.
07-25-2006, 11:35 AM
Just buy used tires guys.
[Image: AEU86 AE86 - what wheel size 13&quot...on hachi ?] http://www.jdmbits.com
07-25-2006, 11:49 AM
nmwisima Wrote:Just buy used tires guys.
not available unfortunately, atleast not here as 14" is as rare as the car itself
07-25-2006, 05:00 PM
oldskull Wrote:Sportmax 002 require rolled fender.
What means rolled fender ? Dumb question any pics ?
85' AE86 GT coupe lifetime project since 2005
07-25-2006, 06:50 PM
It meens you have to go to that special machine shop that car roll the inner part of the fender (where it turns in).
Hope you understand (maybe someone can do it better?)
07-25-2006, 06:56 PM
you can even do that by yourself like this Tongue
But I hope you will do it beter and clean like this Thumbs up!
07-25-2006, 09:09 PM
Well still dont understand what must be done if the outside must be widened or the inner of the fenders need some modify well i think i will better understand if i buy them :-) hope it will go well with 195/50 rubber because on our street is using less then 50 is killing of wheels ...really suck our roads. Too much holes.
If i see it right the 1 pic is with standard height and the red hachi has somethink like coilover setup
07-25-2006, 09:51 PM
The first pic also modified fender, but he did correctly (i think).
You can use sport max without modified your fender, but your rubber (tyres) will touch the fender. Yes of course you can use 195/50 rubber.
Just buy and try it yourself. Smile I am almost buy them too, but I dont want to modify my fender. Still like them original Smile
Oh yes, you can buy Konig Rewinds copy, the wheels named Fast Forward. They are 15x7j 0 offset. The price if I am not wrong about 480 USD for 4 wheels excluding shipping to Europe.
07-26-2006, 08:27 AM
But the rewinds dont have so deep and stepped lip thats the problem and i want it because its just simply looking a lot lot better.
About the fenders its a not big deal you can do it yourself with one tool Smile
07-26-2006, 08:59 AM
Konig rewind copies are a bit weird.. since rewinds themselves are already copies. Rolled fenders are fenders where the lip on the inside is bent out, and then smoothed and painted.
  Spare wheel & spare wheel carrier ondafly 6 1,194 01-19-2026 01:00 PM
Last Post: ondafly
  Shim size for AM cams kazi 4 7,360 12-18-2017 05:34 PM
Wink Hub size kazi 5 12,108 06-09-2017 10:06 PM
Last Post: kazi
  Camshaft sprocket bolt size? harkes 1 6,054 07-03-2015 12:41 PM
Last Post: Dave W
  Oil plug thread size is M18x1.5 ???? Dino86 5 11,849 06-07-2012 04:54 PM
Last Post: Dino86
