valve tick on cylender two intake
12-15-2014, 05:52 AM
Post: #31
Just ordered both testers and will run both. When I do the comp test will I want to turn the crank pully as fast as possible?
12-15-2014, 09:52 AM
Post: #32
(12-15-2014 05:52 AM)dinkers542 Wrote: Just ordered both testers and will run both. When I do the comp test will I want to turn the crank pully as fast as possible?the compression tester has a oneway valve so just turn it gradualy a couple of times untill the gauge isn't going substantialy higher anymore. Apart from reaching the minimum spec you'll also want the cylinders to be even (less than 1bar/14psi difference) AE86 ex-daily |
| 4A-GE valve shim disintegrated | DaLanZhu | 2 | 3,070 |
04-30-2025 12:54 PM Last Post: DaLanZhu |
| 4AGE Valve Buckets Scored | Steller Engineering | 2 | 2,989 |
| 20 Valve Blacktop smoking after engine flush - why? | RolanTHUNDER | 2 | 4,200 |
| HKS valve springs | totta Crolla | 3 | 4,800 |
| AE86 4age engine not starts crank ok backfires to air intake | Ryo | 18 | 25,840 |
08-16-2018 01:36 AM Last Post: Bean |
