trd solid spacer how to?
04-19-2012, 07:18 PM
how do i know what shim i have to use of my trd solid spacer?
04-19-2012, 07:35 PM
I believe you need to measure the rotational torque, afaik it's only purpose is to adjust preload for the pinion bearings. Just pick the shim that gets it within spec.
04-19-2012, 07:55 PM
but how do i measure it? with picture please.
04-19-2012, 07:56 PM
You can check this website
http://www.gearinstalls.com/
[Image: AEU86 AE86 - trd solid spacer how to?]
04-19-2012, 10:11 PM
Don´t waste your time, give it to a diff/ G-box shop.
The cheapet tool to do the job costs 340Euro. That´s twice as much money as you need to get it done in a shop!
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
04-19-2012, 10:38 PM
IIRC Weir Performance had a good writeup on their website of how to
intall a solid pinion spacer.
EDIT: My bad... I was thinking about the LSD upgrade kit. Pretty sure
for the spacer you assemble and torque to spec, then check the preload.
Too much preload, add a thicker shim. Not enough, use a thinner shim.
Assemble, torque to spec and check preload. Repeat as many times as
necessary to get the preload correct.
Cheers... jondee86
04-20-2012, 04:15 AM
It's the same as setting up any 'crush' sleeve, but instead you shim it until it reaches spec.
If you do NOT know how to do this already, I would definetely recommend taking it to someone/somewhere that IS experienced. This is not a job for beginners.
Andrew
04-20-2012, 07:01 PM
thanks. i can do this. but i do not know what the trick is. yet.
04-20-2012, 11:17 PM
Hello ,
you can use a stock shim to adjust the preload.
Remove it and measure it .
You cut the solid space to the same measurement. It needs a great precision.
That's how my machinist do it .
If your interested, he's located in Belgium (Hannuit) ,not so far from you.
I can give you the address and phone (he speaks english)
Regards
Phil
Filh
Save the RWD cars
04-21-2012, 05:19 AM
If you buy the real TRD, install the pinion bearings, the TRD solid spacer + ALL shims. Assemble the pinion gear WITHOUT installing pinion seal. Check pre-load, if too little, remove shim and recheck until it is proper.
Andrew
  4 Puck Solid Clutch Disc filh 11 14,641 11-07-2011 11:40 PM
Last Post: filh
  wheel rim spacer center bore, 60mm ? Uzelac 4 11,951 01-21-2010 08:10 PM
Last Post: aussiefan
  Tokico HTS spacer? Bubble_Drift 27 35,571 07-08-2009 06:43 AM
Last Post: Euripides
  Solid Engine Mounts? PazzaAE86 4 6,784 03-11-2009 12:30 PM
  Solid rear brace? Spitfire 18 21,791 07-20-2007 11:02 PM
Last Post: assassin10000
