rear pad change help
08-01-2009, 11:25 AM
Hi guys,
I need a hand with some info on how to change the rear brake pads for the 86s specific caliper (JDM). I have the old ones out but I cant get them back in. Does anybody have a link or a guide I could use? Thanks in advance. |
08-01-2009, 11:37 AM
You have to wind the pistons back into the caliper. There are a couple
of lugs on the outside, and with the help of a suitably improvised tool, you can turn the piston so that it retreats back into the caliper (it has a thread in back). Once you have them wound back, you can get the new pads in ![]() Cheers... jondee86 |
08-01-2009, 09:09 PM
How about this AEU86 guide:
http://www.aeu86.org/index/brakes-rear-b...post=58817 Should be helpful I think...
| Quick question - Brake Pad Dimensions | Lt86 | 2 | 7,073 |
06-07-2015 12:08 AM Last Post: jondee86 |
| trans oil, lsd oil change | Apolan | 9 | 21,879 |
| Mintex brake pad MDB1193 | Dino86 | 9 | 12,147 |
02-27-2014 11:26 PM Last Post: Dino86 |
| Change the meter between zenki and kouki | T_AE86 | 9 | 14,901 |
12-03-2012 03:13 PM Last Post: T_AE86 |
| Rear ae86 rear discs & pad part numbers? | J-86 | 4 | 8,147 |
![AEU86 AE86 - rear pad change help [Image: AEU86 AE86 - rear pad change help]](https://www.aeu86.org/sticker-banner-468.gif)
