rear pad change help
08-01-2009, 11:25 AM
Hi guys,
I need a hand with some info on how to change the rear brake pads for the 86s specific caliper (JDM). I have the old ones out but I cant get them back in.
Does anybody have a link or a guide I could use?
Thanks in advance.
08-01-2009, 11:37 AM
You have to wind the pistons back into the caliper. There are a couple
of lugs on the outside, and with the help of a suitably improvised tool,
you can turn the piston so that it retreats back into the caliper (it has
a thread in back).
Once you have them wound back, you can get the new pads in Smile
Cheers... jondee86
08-01-2009, 09:09 PM
How about this AEU86 guide:
http://www.aeu86.org/index/brakes-rear-b...post=58817
Should be helpful I think... Dumb question
[Image: AEU86 AE86 - rear pad change help]
  Quick question - Brake Pad Dimensions Lt86 2 6,558 06-07-2015 12:08 AM
Last Post: jondee86
  trans oil, lsd oil change Apolan 9 20,685 10-01-2014 03:57 PM
  Mintex brake pad MDB1193 Dino86 9 11,354 02-27-2014 11:26 PM
Last Post: Dino86
  Change the meter between zenki and kouki T_AE86 9 13,719 12-03-2012 03:13 PM
Last Post: T_AE86
  Rear ae86 rear discs & pad part numbers? J-86 4 7,565 11-30-2012 06:32 PM
Last Post: J-86
