problem on the chassis ? commun on AE86 ?
09-27-2006, 04:22 PM
Hello ! I detected this on the chassis on my AE86 :
[Image: AEU86 AE86 - problem on the chassis ? commun on AE86 ?]
Is it commun on the AE86 ? we told me that yes . I would like to know if that have already happenned to you ? thanks .
The car got an accident in the past . :wink:
09-27-2006, 05:19 PM
it's the accident,dont worry about it Smile
09-27-2006, 05:49 PM
That cars not 100% straight, not a problem so as you know about it, an hour on the jig should sort it
09-27-2006, 07:14 PM
Jig ? sorry I m french . Smile
09-27-2006, 08:18 PM
Jig is a thing that allows you to pull and push on the chassis to bend it back into shape
09-27-2006, 08:22 PM
ok I see ! some people told me that just to, I don't know the verb... "to put a little bit of metal to join the two parts" . we told me too that, that arrive when you drive on track on the AE86 . that is why I asked if it's commun Smile
09-27-2006, 08:25 PM
Well a bit of metal would just cover it up, the question is whether your chassis is straight enough, if the chassis is still slightly bent from the accident it can through the alignment of the car of which sucks on the track.
But if you have no troubles with the stability of the car on the track then I guess its fine.
09-27-2006, 08:32 PM
Ok ! I didn't drive a lot yet . The feeling is weird by I think, it's come from the setup of the rear and front axles wich is not very good . I have to setup it . For example, it's weird . On the front, the car is a lot up (suspension I think) and I have positive camber . there is a lot of think to do on it to setup it well .
09-27-2006, 09:39 PM
Spy, take some pictures, wondering what is installed on the carBig Grin
09-29-2006, 11:08 AM
2 Spy: go to Tyre shop and check the all 4 wheel aligment ... if it's all OK don't woory about it ...
If it isn't OK, then you have a problem.
I have similar thing on my car from some previous accident... but all wheels and aligment are good and straight, and the car doesn't pull on any side on full gas or hard brakeing... Smile
Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62
  New chassis? New chassis! Hype? decryphe 50 22,138 08-31-2026 11:26 AM
Last Post: decryphe
  4A-GE wiring engine to chassis connectors Lykowsky 4 10,512 06-20-2019 11:38 AM
Last Post: Lykowsky
  frame/chassis rails info Tig 14 27,928 12-22-2012 10:38 PM
Last Post: Tig
  4agZe problem solved - 99% IC problem Okami 41 51,245 07-12-2012 04:49 PM
Last Post: Okami
  AC problem? Idle problem? KD2229 3 6,732 08-19-2009 02:08 AM
Last Post: KD2229
