please help!!! ( rear axle )
07-13-2010, 12:14 PM
I want to weld my diff but I can't pull the axle out. haw do I do it?
pls help me ...I have 1 week till next drift event! http://s1.postimage.org/ac0kA.png |
07-13-2010, 01:09 PM
download the body manual from the website and look into that. Think that is the most easy way.
07-13-2010, 09:14 PM
I'll tell you how.....
if you get rid of your video avatar thing or whatever it's called Deal ? :wink: An analogue brain in a digital World |
07-14-2010, 09:01 AM
totta Crolla Wrote:I'll tell you how.....done... http://s1.postimage.org/ac0kA.png |
07-14-2010, 11:16 AM
i really need help ...anyone????
07-14-2010, 11:40 AM
I guess you mean you can't pull the halfshafts out of the housing? You either need to make a SST to fit on the halfshaft flange and hammer it out, or (at your own risk) hammer the flange directly out. The relevant toyota SST is shown in the repair manual, as does the procedure for rear axle overhaul if you go through it...
SFD |
07-14-2010, 03:13 PM
You need a slide hammer puller.
Mine is this one, bought at machine mart
07-14-2010, 08:32 PM
Spawns... I feel real bad now
Anyway I tried a slide hammer like the ones shown, no luck. I bolted an old steel wheel onto to the hub and hit the back of it with a real big hammer. Once it had moved a fraction I sprayed some WD40 around the bearing and after soaking for a while the shaft came out fairly easily. Take off the caliper complete with carrier, remove disc and remove the four bolts holding the bearing retainer in before any of the above though. An analogue brain in a digital World |
| AE86 rear axle weight | megabob | 11 | 23,209 |
| Axle width | totta Crolla | 1 | 2,463 |
| TUV RHD AE86 Germany (help please) | 4dori | 9 | 9,656 |
07-17-2019 07:42 PM Last Post: Hachigo83 |
| Rear axle options | Dino86 | 13 | 17,975 |
| Carb question please help | MIGGZFSU | 3 | 6,146 |
03-29-2017 03:06 PM Last Post: MIGGZFSU |
![AEU86 AE86 - please help!!! ( rear axle ) [Image: AEU86 AE86 - please help!!! ( rear axle )]](http://img845.imageshack.us/img845/1082/capturar01.jpg)
