part number needed: 4age bluetop pistons
11-15-2006, 12:07 PM
I'm rebuilding my bluetop 4age engine and it needs to be bored to 81.5mm (stock size 81.0 mm). This means i'm on the market for new bluetop pistons. I'm specifically looking for european or japaneese bluetop pistons since their compression ratio is higher than the us version.
So, please, if anyone could help with a euro or j-spec part number of bluetop pistons...
Thanks a lot! Smile
1984 Toyota Corolla 4AGE 20v
2007 Subaru Impreza STi
11-17-2006, 09:47 AM
still looking...
11-17-2006, 01:12 PM
Hi,
OEM Euro Pistons - 13103-16030-02 (64.74 € each)
OEM Euro Piston Rings - 13011-16180 (105.75 € set)
Over Size 0.5 Euro Pistons - 13103-16030 (64.74 € each)
Over Size 0.5 Euro Piston Rings - 13013-16050 (105.75 € set)
:wink:
11-17-2006, 01:40 PM
Rasteirinho Wrote:Hi,
:wink:
You rock! Thanks! Smile
11-17-2006, 06:06 PM
tell us about the prices too !!!
11-17-2006, 06:23 PM
Ok, post edited.
Prices in Portugal.
11-17-2006, 07:23 PM
I'm suprised to see that prices of rings and pistons are the same.
I'll post local prices also for comparison.
OEM Euro Piston Rings - 13011-16180 (64.74 € each)
Over Size 0.5 Euro Pistons - 13103-16030 (105.75 € set)
:wink:
By the way, what do you mean by "105.75 € set"? Is this for 4 pistons or less?
Thanks again Smile
11-17-2006, 11:14 PM
Sorry, i'm wrong
64€ the pistons
105 € the rings
11-21-2006, 11:06 AM
Does anyone know the specs of those pistons?
I was thinking about ordering a custom set from Arias - 81.5mm, 11.5 compression. I know they have the redtop pistons, but i don't have the redtop internals.
This is what Arias are looking for before accepting an order:
• Engine make, model & year
• Bore size
• Stroke
• Rod length (c to c) and material
• Block height
• Compression ratio
• Gasket thickness & diameter
• Wrist pin diameter
• Pin offset and direction
• Application info
• Induction & fuel
• Camshaft specs
(gross lift, lift @ TDC)
• Cylinder head brand
model & part #
• Valve angle
• Combustion chamber CC’s
• Valve diameters & freedrop (valve edge to cyl. head deck)
• and quantities of pistons and hardware.
  82mm Stock compression Pistons apardal 4 3,468 11-24-2021 04:26 PM
Last Post: apardal
  Bluetop Engine Rebuild multiple question Goal 150-160hp Hanzo 16 11,259 04-19-2021 10:08 PM
Last Post: Hanzo
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 13,194 02-10-2020 06:39 PM
Last Post: Power_uP
  Small Port 10.3 Pistons Alex170984 1 4,726 10-25-2016 09:18 PM
  Bluetop on turbo leon205gti 7 8,702 09-20-2016 09:17 PM
Last Post: leon205gti
User(s) browsing this thread:
