part number needed: 4age bluetop pistons
11-15-2006, 12:07 PM
I'm rebuilding my bluetop 4age engine and it needs to be bored to 81.5mm (stock size 81.0 mm). This means i'm on the market for new bluetop pistons. I'm specifically looking for european or japaneese bluetop pistons since their compression ratio is higher than the us version.
So, please, if anyone could help with a euro or j-spec part number of bluetop pistons... Thanks a lot!
1984 Toyota Corolla 4AGE 20v 2007 Subaru Impreza STi |
11-17-2006, 09:47 AM
still looking...
11-17-2006, 01:12 PM
Hi,
OEM Euro Pistons - 13103-16030-02 (64.74 € each) OEM Euro Piston Rings - 13011-16180 (105.75 € set) Over Size 0.5 Euro Pistons - 13103-16030 (64.74 € each) Over Size 0.5 Euro Piston Rings - 13013-16050 (105.75 € set) :wink: |
11-17-2006, 01:40 PM
Rasteirinho Wrote:Hi, You rock! Thanks!
11-17-2006, 06:06 PM
tell us about the prices too !!!
AE86 FANATIC!!! |
11-17-2006, 06:23 PM
Ok, post edited.
Prices in Portugal. |
11-17-2006, 07:23 PM
I'm suprised to see that prices of rings and pistons are the same.
I'll post local prices also for comparison. Rasteirinho Wrote:Hi, By the way, what do you mean by "105.75 € set"? Is this for 4 pistons or less? Thanks again
11-17-2006, 11:14 PM
Sorry, i'm wrong
64€ the pistons 105 € the rings |
11-21-2006, 11:06 AM
Does anyone know the specs of those pistons?
I was thinking about ordering a custom set from Arias - 81.5mm, 11.5 compression. I know they have the redtop pistons, but i don't have the redtop internals. This is what Arias are looking for before accepting an order: • Engine make, model & year • Bore size • Stroke • Rod length (c to c) and material • Block height • Compression ratio • Gasket thickness & diameter • Wrist pin diameter • Pin offset and direction • Application info • Induction & fuel • Camshaft specs (gross lift, lift @ TDC) • Cylinder head brand model & part # • Valve angle • Combustion chamber CC’s • Valve diameters & freedrop (valve edge to cyl. head deck) • and quantities of pistons and hardware. 1984 Toyota Corolla 4AGE 20v 2007 Subaru Impreza STi |
| 82mm Stock compression Pistons | apardal | 4 | 4,554 |
| Bluetop Engine Rebuild multiple question Goal 150-160hp | Hanzo | 16 | 14,405 |
| Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 16,313 |
| Small Port 10.3 Pistons | Alex170984 | 1 | 5,426 |
10-25-2016 09:18 PM Last Post: oldeskewltoy |
| Bluetop on turbo | leon205gti | 7 | 10,113 |
09-20-2016 09:17 PM Last Post: leon205gti |
