oldskull's Levin
10-22-2006, 09:53 PM
Post: #131
oldskull's Levin
Ah oke Mux, bedankt.
Ik ga over 2 weken naar de APK. Sad
10-22-2006, 09:54 PM
Post: #132
oldskull's Levin
oldskull, ik heb ze wel liggen. Alleen zit ik niet in de buurt.
Zal wel iets van 200km tussenliggen.
10-22-2006, 09:57 PM
Post: #133
oldskull's Levin
Ik heb er ook wel 1 voor je.
Woon een stuk dichterbij. Thumbs up!
[Image: AEU86 AE86 - oldskull's Levin]
Toyota MR2 2.0 16V Gen3 Turbo
Toyota MR2 1.6 16V
10-22-2006, 10:06 PM
Post: #134
oldskull's Levin
toppie man! Thumbs up!
@toypower: als niemand anders die dat ding heeft dan rij ik gewoon naar jou toe.
@circuitfreak: pm'en Thumbs up!
10-22-2006, 10:15 PM
Post: #135
oldskull's Levin
Je hebt een pmetje terug. Thumbs up!
Toyota MR2 1.6 16V
10-23-2006, 05:11 PM
Post: #136
oldskull's Levin
@Banpei: I think wiring up new relays might not be very practical, might be better of running a wire with a diode in it from the normal rear light to the corresponding coil on the foglight bulb. That way you only need one wire and it will work for both sides at the same time (usually).
I'd keep the brakes on one single light per side though, wiring both up is officially illegal over here. My car failed MOT on that last year (amongst other things), I asked him to show me where it said so in the law and he let me have a look in the book.
According to NL law the brakelights must be an un-interrupted set of lights on each side.
10-23-2006, 08:23 PM
Post: #137
oldskull's Levin
Hey Ivan, thanks for the info, I will put the cable from EU one for MOT Smile
10-23-2006, 10:29 PM
Post: #138
oldskull's Levin
Ivan141 Wrote:@Banpei: I think wiring up new relays might not be very practical, might be better of running a wire with a diode in it from the normal rear light to the corresponding coil on the foglight bulb. That way you only need one wire and it will work for both sides at the same time (usually).
True. Bit stupid indeed. Banging head
Didn't think that way, more or less to prevent current somewhere along the line, but ofcourse if you keep it inside the light itself you don't need to do that. Tongue
10-23-2006, 10:49 PM
Post: #139
oldskull's Levin
I described a similar procedure for the regular coupe rear lights waayyy back in the first montsh the forum existed. You just use a jumper wire from the correct terminal on a rear light cluster, and connect it to the light you want to switch with a diode in series. Make sure it's at least a 6 ampere rated one, you dont want it to burn out, and maybe change the taillight fuse accordingly to correct for the extra current draw.
The nice thing is that the rear light circuit is basically a parallel network, so if you connect the wires on one side, it will work for the other side too. If you're handy with crimping connectors you can make it easy to remove as well, for MOT purposes.
11-22-2006, 06:12 PM
Post: #140
oldskull's Levin
MOT passed!!!! Thumbs up! Hurray!
Nothing where wrong but the rear fog lights.
I put the EU rear lights cable back for the MOT but after test the rear fog lights and the inspecteur ask if the switch also got light on, and it was not and he asked me to removed the lights bulb for fog lights. Thats it, and the car passed! Also thanks to CircutFreak for replaced the bend rear arm for me Thumbs up!
So I can put the USDM rear lights cable back! Thumbs up!
