oldskull's Levin
09-19-2006, 06:51 PM
Post: #101
oldskull's Levin
unless you have something to make nice square (or almost square) holes with I dont expect it's very easy.. the original sideskirted cars had sills that where pre-stamped to fit them I think.
09-19-2006, 07:01 PM
Post: #102
oldskull's Levin
Ivan141 Wrote:unless you have something to make nice square (or almost square) holes with I dont expect it's very easy.. the original sideskirted cars had sills that where pre-stamped to fit them I think. Exactly, I think thats your hole problem. The original sideskirted cars already rot like hell even if you took proper care of them due to rot settling in. Let alone if you start drilling holes into a body and then somehow try to rust proof those holes with a car that didn't have sideskirts. I think the best route is to make sure the layer of paint on the body work is rock solid, then glue the skirts on and make sure moisture can't be trapped inside by leaving some holes in the underside of the skirts and then just filling the things up with some anti rust stuff like waxoil or something.. but thats just my humble opinion Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
09-19-2006, 08:57 PM
Post: #103
oldskull's Levin
offtopic@mux:
but at 4636 posts you automaticly became one of our experts He attacked everything in life with a mix of extrordinary genius and naive incompetence, and it was often difficult to tell which was which. |
09-19-2006, 09:07 PM
Post: #104
oldskull's Levin
Senna, uhm
09-20-2006, 12:14 AM
Post: #105
oldskull's Levin
The kit I used to work with in bodyshop is PU-kit, polyurethane-kit, they sell at carpaint shop not Gamma or so, just cost € 6 each tube.
It's so strong you can even glue small brackets and stuff with it, it's sorta like rubber when dry and even paintable afterwards to make a seamless skirt. If you like I can search for brand, let me know. Disclaimer: Any errors in spelling, tact, or fact are transmission errors. |
09-20-2006, 08:46 AM
Post: #106
oldskull's Levin
Seth,
Sounds like the stuff Martijn used (he worked at a body repairshop so) Didn't know you worked at a bodyshop mate
09-20-2006, 11:11 PM
Post: #107
oldskull's Levin
That was 3 years ago, if I knew then what I know now.....
I sure would have done more. But I still have contact with some guys at that shop Disclaimer: Any errors in spelling, tact, or fact are transmission errors. |
09-24-2006, 03:17 PM
Post: #108
oldskull's Levin
Hehe keep the contacts warm
Anyways got some email back from Martijn, he mentions the same kit you use to glue in the front window works miricles in fixing fiberglas body parts to a car. You need to use the kit in combination with a 'primer' that you just glue on both the body and the fiberglas part and then you apply the kit and it sticks very good. If you ever need to remove it you just cut it loose with 'fish wire' (dunne know what to call it, the special sharp metal wire) or a razor just like you would with removing the glass. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
10-02-2006, 04:25 PM
Post: #109
oldskull's Levin
Weet iemand hoe kan ik mijn achterlichten laten polijsten. Ik heb andere achterlichten van Max gekocht maar de kleur zijn een beetje dof.
Kan iemand mij vertellen wat voor spul moet ik gebruiken om weer bling2 te krijgen
10-02-2006, 04:42 PM
Post: #110
oldskull's Levin
Ik heb het gedaan met gewoon papier...
Wrijft goed over de lichten (droog) en als het goed is zie je dat er vuil in het papier gaat zitten wat er niet afgaat als je em wast. Na dit moet je met LCD cleaner doekjes eroverheen, als het goed is zijn ze nu netjes. 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
