nzae86's TRD ae86 N2 Race Car Project 2,
04-05-2010, 05:02 AM
Post: #291
I should be up loading photos that show huge amounts of progress to this project but I have been doing other things lately and almost forgot about this thing.
Anyhow I have finished the wiring to the stage where it winds over on the starter , with oil and fuel pressure , and all other electrical things working except for the engine management wiring, that will be next.
Today I tacked my exhaust system together and will get it tig welded tomorrow, looks like it could be a noisy beast!
[Image: AEU86 AE86 - nzae86's TRD ae86 N2 Race Car  Project 2,]
There's not much to it when it is on the ground
Also while I was hunting around on the net one day I found a set of these TRD Tosco rims, so had to have them!
Your addiction to motorsport can only be cured by poverty !!
04-05-2010, 05:32 AM
Post: #292
Nice, thats how Ill be doing mine too. What size did you go? Im planning stepped 2.25 > 2.5
Its great as that design keeps the car road legal for targa events etc Smile
04-05-2010, 09:14 AM
Post: #293
4000GT Wrote:Nice, thats how Ill be doing mine too. What size did you go? Im planning stepped 2.25 > 2.5
I am using 2 1/2 inch stainless for a start and if this doesn't work well ,I will try 3 inch.
cheers
04-05-2010, 09:36 AM
Post: #294
Ah ok, did you simulate the resonance, velocity and back pressure of going straight to a 2.5" system? You didnt see the need to step it up at all?
04-06-2010, 03:08 AM
Post: #295
4000GT Wrote:Ah ok, did you simulate the resonance, velocity and back pressure of going straight to a 2.5" system? You didnt see the need to step it up at all?
No just took the approach that if it doesn't work I'll build another system that may work !
04-06-2010, 06:19 AM
Post: #296
Nice Smile
What city are you in? Going to do Superlap?
04-07-2010, 03:20 PM
Post: #297
I have good results with 2½ inch to the middel of the car and then step down too 2inch the rest of the way. I gain 8-10hp on my 174hp 20v with that solution, insted of 2½inch all the way. Its an old rallytrick.
Actually its because the gas gets colder at the end of the exhaust and then a smaler pipe will give a better flow.
But since you have such a short exhaust, I don't think it matters. I belive this engine will pull out 215hp+ even with a banana in the exhaust :wink:
Cant wait to see some videos Hurray!
Project AE86 now begun.
Cars I have owned:
Toyota Starlet EP91 1,3 16v Turbo, 200hp
Toyota Starlet EP71 1,3 12v Sport
Mercedes 207D camper, 1977.
Toyota Starlet EP70 with a 174hp Silvertop 20v See video here:
http://videos.streetfire.net/search/Star...079edc.htm
Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint).
Volvo 240 2,1 (The only car I have maked money on).
Toyota Corolla EE90 (my first car)
04-08-2010, 01:27 PM
Post: #298
Jimmi The Kid Wrote:I have good results with 2½ inch to the middel of the car and then step down too 2inch the rest of the way. I gain 8-10hp on my 174hp 20v with that solution, insted of 2½inch all the way. Its an old rallytrick.
A smaller pipe does not get better flow, it increases the velocity of the gas because the pipe is smaller, following that logic you would use the smallest pipe possible. The issue is that the gasses cool, and get more dense, and slow down, and you want zero backpressure (while allowing scavenging). Because the gas is more dense and slower, you need a bigger pipe to account for the reduced capacity, the boundary layer thickness in a small pipe again reduces flow. You want a megaphone type approach, increasing in size...
04-21-2010, 09:17 PM
Post: #299
sorry, maybe it's stupid i ask... but why did you remove the foam out of the fuel cell?
http://bruutt.blogspot.nl/
04-22-2010, 09:02 PM
Post: #300
einneb Wrote:sorry, maybe it's stupid i ask... but why did you remove the foam out of the fuel cell?
Hi there
I only removed the foam temporarily while I was cutting and drilling holes in the plastic to fit the sender unit so no small bits of plastic would end up in my fuel supply later on , I reshaped the foam and cut it around the fuel sender , and refitted it .
Cheers
  nzae86's AE86 Levin Tarmac rally car build Project 1 nzae86 30 66,369 04-30-2013 07:28 AM
Last Post: nzae86
  my celica race car with race beams Celica RA45 14 25,335 09-14-2011 11:50 AM
Last Post: Celica RA45
  AKR's Daily-driver-race-car asian knight rider 5 12,740 11-01-2009 12:25 AM
Last Post: doggy
  My Project car :D Muchomuchacho 5 8,550 06-05-2008 05:15 PM
Last Post: Muchomuchacho
  A.D.D Performance Demo car (AE86 project) cab32 15 21,821 03-24-2008 03:34 PM
Last Post: cab32
